  • Replies 57
amarnew in the straya (think how u boy said irt) and got myt nu skylien coz i saw alot sexy man drive this one whe i get hea frm d arrprt then i sad amar get 1 wen i ken get muny and meet tha boys in the sites in cruising and make liftiem conexion with you Aaeron u seem lyk da nice guy that willl do it fur me cany we plz get off 2 nice start and holt hand outta window togetha whil we dreveng?
Is this you OP?
385449_10151253698745868_1702464392_n.jp
Obey caps are pretty cool...I guess...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
