when i purchased my gtr, the owners brother(owner wasnt there, everything was legit, so all good), handed my os giken twin plate(needed rebuild).
looked underneth, had tien coilovers.
trust 4inch cooler.
tuned y pipe, 3inch cat and cat back.
those were the parts i didnt know of.
did you check and see how good the ah 'mines ecu' under the back seat was, or did you just throw it out?
Tossed it ,it was not in very good condition,i think it had been there a while.
Edited by I gotta R34gtr v-spec
I bought my 34 a long time ago.. About 2 years after i bought it i went to install red bulbs behind my dash. I took the dash apart then went reaching in behind there and found some wires that seemed a bit "out of place".. So i looked up under there and followed the wires back and found a Greddy full auto turbo timer sitting in there!? hidden amongst all the other wires. All i had to do was turn it back on and mount it and boom. Free turbo timer. :D Also found a Japanese jdm game token coin like thing under my seat..
Found a 1979 20cent piece behind the roof vinyl interior of my 1981 Stanza. So I can only assume the coin was lost there while the car was on the assembly line. Still have the coin somewhere....
Jeff
  • 2 months later...
Found yellow jackets tucked down the left side of my r32's boot still in there packets! (Hopefully will fit my rb20) :)
Was looking at buying rear hicas lock bar.. Had a look underneath and already had one :)
Nismo front strut bar with Nismo stamped into it (hopefully genuine.. Not sure if those are even rare..
And last but not least about $18 worth of shrappaz!
In my 33 i Found split fires, dodgy wiring in the tail lights, really old jdm gaff tape in the doors, wierd wires all through the car, a USB with the guys birth certificate license and all his tickets, jdm coins, aus coins $14 worth, Japanese rego sticker
And the classic dried up maccas chip
4 children's nursery rhyme CDs behind the dash, played that shit all day!
Shell battery from Japan? You can't buy them here.
Shell service stickers all over and in the car from Japan.
On my gf car I found a threaded head with the spark plug sitting on top and some more threaded bolts on the thermostat housing. It was a fluke it even ran.
found tanabe GF210 on my stock springs heh i knew them orange springs were weird! also found the lock nut key from previous owner's set of nuts, which he had the tyre guys smash off, thus running only 4 nuts (until i bought a new set of nuts). what a nub. it was in the compartment which had the spare tyre jack in it, i noticed something rolling around inside.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
