Was installing friends turbo timer in R33 GT-R, took the steering wheel surround off, spliced the cables, hooked it up. It all worked as expected. So we were deciding where to locate the timer and he decided stick it near the ashtray, opened up the center console, guess what's staring at me?
Greddy Turbo Timer.
It was even hooked up, stealthy, not turned on, but plugged in :)
Story of my life.
In my old R32 GTS-t when i bought it 10 years ago (traded a year later), it came complete with a ceramic turbo wheel in the cat.
Then on i knew this car was guna be trouble..... boy was i right.
Safe to say, i no longer have this car lol.
found 4 x 10 yen coins under the carpet
and some tv antena's stuck on the rear glass with cables running to under the passenger seat
and factory xenons still fitted and not at all butchered!
Decat on my first skyline and in my new one an assortment of shit tools in the boot and some random wires under the passenger seat. Also found out from a mate who was drivig behind me that I had the skyline on the rear of the r33 lighting up which was cool. Also found out I had an awesome set of front and rear speakers.
  • 4 weeks later...
  • 9 months later...
I recently changed out my radio to a more up to date one. I have owned my R33 for a year now. I assumed the USB cable in the ash tray was for a MP3 player connection of some sort but never tested it out cuz I don't own one. As I was replacing the radio, I noticed the USB cord did not connect to the radio but kept going to somewhere behind the passenger side dash. Removed the glove box to find a Greddy eManage unit! Go figure...
Another time was when replacing the valve cover gaskets and found my whole entire head was built by HKS. They even have their stamp into the head itself.
Find myself pretty luck on this purchase since there's more top name parts on the car than what I've paid for the car.
  • 5 months later...
recently went with a pressure washer under my car to clean the suspension area and to my surprise i noticed HKS springs. I have the car for 7 years now and never knew. And can't find any info about them on the internet. No wonder my car always felt so stiff on the road.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
