  • Replies 214
leigh , work on your bench tecnique if you can for the next lifts. You need to practice changing the angles on your lift so you don't hurt your shoulders. Your vid shows there is lots of stress going onto the rotator cuff. Basically, see if you can take a slightly narrower grip and lower the weight in a slight arc to just below the nipples on the chest. Keep your shoulder blades retracted in the lift. It will feel initially weird but, give it a go and see if it helps.
cool i'll give it a go next time I'm at the gym cheers
Good advice!
Partner did 30 @50% bw today
lol she wins if you can put up a vid
Prolly should have made it 60%, as I read that females have 60% the upper body strength of males, but it wouldn't have made much difference. Well done to her!
Yes well I think the Kara's of this world make good exceptions for a level playing field ha ha... anyone bench 182kgs at 67kgs bodyweight?
She squats 275kg and deads 225kg.....ouch.
Edited by rev210
Come on Leesh and Charlie...lol
Farking...giving up on life now.
Slightly unimpressive deadlift? Only compared to the bench and squat...
You should throw up some before and after pics of weight loss in your thread (preferably Skyline window reflection). It's quite an achievement at your age (and gives me hope for the future lol).
on your suggestion I just posted in my thread on the build section. I don't have the skyline window tho' so they lack style.
Edited by rev210
Have John (SRS13)'s attempt ready to post, but we're having a bit of tricky trouble with emails and attachments not being forwarded at the moment. Should have it sorted tomorrow hopefully. Sorry John!
No problems!
Sorry for the headache and thanks for helping out.
What was your bodyweight John? 80kg from memory?
Good form and solid reps throughout! Almost had the 19th...
SRS13
BW: 80kg
BP: 80kg x 18
http://www.youtube.com/watch?v=_irH8fbKbHs
Claim is useless without vid...post up Troy. 9 reps is nothing to sneeze at.
cbf recording it unless I know I'm in contention for the win :P I'm happy enough with 9 reps of bodyweight though, so I'm not entirely disappointed. Hopefully I can get it up to video-worthy level before end of month :D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
