  • 3 weeks later...
Nah I just want a standard one with the front chopped or a legit GTR one. Only running this one as this happened unfortunately.
Edit. Forums being gay can't upload pics. Bonnet made love with windscreen and roof.
I remember when your 6th piston didnt like the world and overheated.
quick question, are you still running the gktech clutch Fan?
Because ive heard nothing but problems with that fan on Neo engines, Stock is better.
stock fan with a decent radiator works tits, those GK Tech fans are hideous - pointless mod, I removed two of them off 2x S15s that were overheating on the track.
Yep still using GKtech fan. Temps are fine but haven't abused it on a really hot day yet. I need to find a R32 radiator shroud first then a stock clutch fan that actually works which will be difficult. Once I have all the parts I will do it then :)
Have Gktech fan on S2 RB25, stock shroud, temps are great, done many laps with no problems. Only complaint is fan hub is always locked when running, but don't know if that's because of the fan or not.
Bought a shroud, should be here mid week. Doing a drift day at wakefield next Monday so I'm super keen for that.
Bought some tyres to get out on rims, as did my friends. Lucky we have access to a tyre changer!
  • Like 1
  • 3 weeks later...
Cam seal has been leaking since the car has been running. Decided to fix it today. Pulled all the shit off and found scoring in the exhaust cam, and also found some black shit on it as well, looks like the seal may have been unlubricated and is slightly melted onto the cam. Sweet.
So undecided what to do at the moment. Will grease them up and has been suggested to put the seal back in but not in the same position as before. IE 1mm further in or out.
Also had planned to do a wakefield drift day 2 weekends ago, but the night before it the MAP sensor on my ECU dishonoured it's family and killed itself for some reason. So took it to Jez and he swapped it over for me (top bloke).
Fun times.
post-84937-1429443694734_thumb.jpgpost-84937-14294437116086_thumb.jpgpost-84937-14294437318415_thumb.jpgpost-84937-14294437609681_thumb.jpgpost-84937-14294438267172_thumb.jpg
I'd like to know how you get the timing right, is it just a matter of getting the right belt , install tensioner on block and just line the marks up or is there a more precise way to get it spot on?
Can you get adjustable wheels for both intake and exhaust side then? Just trying to visualise how the crank and two cams can be in the exact spot without having everything adjustable..
Can you use the tensioner for adjusting it too? hmm
Edited by AngryRB
Was just after a quick answer, i know what a tensioner is for, thanks for your wise answer, its an hour drive each way with an engine on the ute for me so id rather learn on here... from what ive read so far, the timing on an RB30DET can be tricky compared to a stock RB25, ill just line the marks up and let my tuner check and adjust it before its tuned then.. ;)
Edited by AngryRB
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
