The goal is to train 85-95%. The reps will be low. 2-5 . This range is proven to be the most effective in strength improvement. A variety of methods adopt this in different ways.
The concensus seems to be a pure 1rm is best done very sparingly in a training shedule.
Since you don't know how to do them properly Bozodos, I'd suggest sticking to what you are doing. Once you get taught correct tecnique, then go crazy. assuming your goal is to focus on a 1rm improvement over time.
I am in this boat with you. I am not training this movement heavy till such time as I am given competent instruction. Even then interest in 1rm as any kind of training methodology beyond that. Reserved for some sort of lifting test maybe every 3 months or a comp or beer inspired show off session or all 3 at once.
The program Max has devised for our PL team has a 1RM in Week 10 of the program (PTC Method)
So our crew only hit singles once every 10 weeks, then again 2 weeks later at the meet.
In the past though, when our guys were not as strong, we did test 1RM more frequently, as it took less out of the guys.
To give you some idea, Max had never ever loaded a 270 squat, 170 bench or 260 deadlift in the gym before making those lifts at Nats. Because he had successfully completed PTC Method for 10 weeks, plus last week off completely, he was uber confident of making lifts he's never attempted. Thats good programming.
Because at PTC, no one cares what you hit in the gym
  • Like 1
90kg x 10
120kg x 10
150kg x 5
190kg x 1
Went for something different tonight. I want my volume to catch up with my 1RM training, as the gap is getting too big and I'd like to focus on improve my form on the heavier weights. So I pushed the volume weights up by 10kg. Once I get the volume up to around 170 for a few reps, I'll shoot for 200 and beyond. Was pretty happy though, as 170 used to be my 1RM not that long ago. Couldn't resist a single to finish off.
90kg x 10
130kg x 10
160kg x 4
170kg x 2
180kg x 1
I deadlifted without the aid of chalk or straps for years and then one day an Army mate I chatted with in the gym from time to time gave me a bag. Huge difference!
My current deadlift routine is usually:
6 x 100kg (warm up)
8 x 160
8 x 170
5 x 180
1-2 x 190
8 x 140
Followed up by 3 sets 10 x 60kg DB bent-over rows and 3 x machine lat pull down.
Chalk is ultimate though, should buy some and take to gym,
6 x 100kg (warm up)
8 x 160
8 x 170
5 x 180
1-2 x 190
8 x 140
good job, when you trying for 200?
I'm actually training back tonight, so might even give 200 a go. Probably go straight from my warm up to a few reps at 160 and then try 200.
I've been using the routine I detailed above (with the odd variation) for months so probably time to mix it up a bit. I tend to get comfortable at a certain level with my training and don't push myself into new territory very often.
One of the advantages of military life is the time and access to excellent quality gym's. I've been training for years and tend to just train for health and fitness rather than try to set PBs for bragging rights these days.
awesome, good luck, sounds like you have the right attitude.
Yeah cheers.
There are some strong lads in the gym on base, some of them get right into lifting bigger numbers. One of the younger guys I trained with a bit last year and earlier this year was routinely deadlifting 270-280 1RM... after pulling multiple sets at lighter weights. He did the same with bench - peaked at 180 last time I saw him. This kid was about 6'4, low 100's and all of 19yrs old!
Well I followed through with my comments earlier today about giving 200kg a shot.
I warmed up with 8 x 100kg, followed by 8 x 160, then did 2 x 200 easy enough that I decided to try 210... and I managed one without resorting to poor form. Dropped back to 170 but after 6 I was pretty much gone.
I continued on and did 3 x 8 60kg DB one arm upright rows and 3 x 8 lat pull down, but unlike normal I'm feeling noticeable more shagged. Might shift squats to Fri.
In general not sure why anyone except guys who compete don't use straps and forearms will always fail before the back does
I've always done deads last on back day as there's no energy left after them
On high rep sets my grip gives way...on low reps and singles, my back gives in first. But that's okay; both play catchup on each other. Why train around the weakness and create a dependence in equipment? I want my forearms to be strong too. You're only as strong as your weakest muscles.
As for deads last on back day, I used to do the same...but now I stick it up front as rows and pulldowns rob you of performance. They are assistance exercises to the deadlift and should be done after, so you don't fatigue support muscles early on.
Nice work there. Is that a pb for you? What do you weigh and how tall are you?
Thanks L33SH.
Thanks Birds. Yes mate it is a PB, I usually rep my way up to 190 (until tonight) not beyond.
I'm 183 / 6' and came in at 88kg on the scales tonight.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
