90kg x 10
130kg x 10
167.5kg x 5
185kg x 2
90kg x 10
130kg x 10
170kg x 5
185kg x 1
180kg x 1
New 5 rep pb of 170kg - very happy with this! That's a 10kg increase in 2 weeks. Unfortunately, it taxed me for the second rep of 185kg, so left it at a single and dropped back to 180kg.
Will try to secure the 185kg x 2 after the 170kg reps next time.
  • 3 months later...
90kg x 10
130kg x 10
170kg x 5
185kg x 1
180kg x 1
Been a while since I've been able to update this with an improvement!
Amidst holidays, a new job and a new gym, I caught a bad run of tonsilitis a while ago, which caused me to drop 4kg of bodyweight (if you thought I was skinny before, lol...) and instantly lose 10-15kg off all my lifts. Annoyingly, it has taken ages to recover the strength, let alone surpass it, despite how quickly I lost it in 2 weeks of no gym and not being able to eat. It's like my body ate its muscle :/
Anyway, I am back to doing what I love and touching on old PBs. My new gym has a shortage of small weights, which necessitated the stepping up of my warm up and working set weights by 10kg, so that I could get the damn things done with just 20s, instead of waiting around for someone to finish quarter squating 55kg. The consequence is some taxing up top, but overall I'm lifting more weight and as the working sets go up, so does the ability to lift more weight on the 1RM. So exciting times ahead for me assuming I don't get sick again or die.
100kg x 10
140kg x 9
187.5kg x 1
170kg x 3
160kg x 5
Finally pulled 200kg yesterday and it was on a texas power bar, not a texas deadlift bar, no belt either. Could be more in it with those, who knows. I almost shat a lung doing it but meh, its finally good to break through the barrier!
Edited by Mitcho_7
Finally pulled 200kg yesterday and it was on a texas power bar, not a texas deadlift bar. I almost shat a lung doing it but meh its finally good to break through the barrier!
Grats Mitch!
How long did it take to lock out?
Have you been trying the 200 for long?
First time attempting it yesterday.
It was fine off the floor, but once I get to my knees its always a grind. Im weaker in deads from 4" blocks so ive just been doing heaps of block pulls and pause deads to help try and rectify that
  • 4 weeks later...
  • 1 month later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
