Jack stand on the chassis, tsk :no:
Word of advice with the HICAS light, don't just remove the bulb. If you ever need to get the car inspected, the pits guys know to look for that. All the lights should come on when you switch the key to on, if it doesn't they know you have removed the bulb. Best way to get past it is to wire that bulb into one of the other bulbs, so that it will come on when the key is switched on.
Strangely enough they aren't worried about HICAS being deleted, just the fact the light doesn't work. They're an odd breed.
Where's best for the stands? :S
Thanks for the tip on the light. In Dubbo it wouldn't be much of an issue. Most people don't even know what a Skyline is let alone HICAS :P . Good to know though as I plan to go to Sydney for some events along the way :)
Just FYI for next time, those aren't pressure plates. They are the clutch plates.
I love guys who are DIY and hands on :) So good work mate.
My bad haha. Like I said I'm not the most mechanical person myself, and I was relying solely on my friend to get all the work done. I was just a work horse so to speak hahaha.
Thanks for the kind words :) Hopefully I get to do a bit more myself, I love actually working on cars (especially my own) but just don't have the full know how to do everything on my own lol.
Hey with the Hicas bar on R34 is it as important as with 33 ans 32s because i thought 34s have the electronic Hicas unlike the Hydraulic ones that eventually break.Shed some light on me if im in the dark.
Hey, I'm a little confused by what you're asking. Do you mean is it important to replace to prevent it from breaking? If so, I'm not too sure, I simply fitted the lock bar to get rid of the HICAS I was want to get track my car (when I eventually get to it). I did not read into the 'reliability' of the HICAS in R34's to know whether they are likely to break or not. The only 'advice' I can relay in regards to that is that my car has just over 150,000kms on it and I believe it was the original HICAS unit. Hopefully this helps.
HICAS is broken from the factory.
Timmy which springs did you get? I have some incoming brand new bilsteins and searching round for a set of springs to match up!
I just bought second hand King Springs on ebay (I plan to fit coilovers at some point so didn't want to buy new).
I'm pretty sure King Springs only have one model number for front and one for rear so whatever that is sorry lol. I can look for pictures of the model numbers if you are stuck.
  • 1 month later...
Hey all. Competed in a local 1/8th mile drag meet today. Was good fun, even managed to take out the win in the bracket I was put into.
Photo from setting up in the morning.
Trophy ^_^
Will post some vids up when I get the chance during the week :)
  • Like 1
Here is a phone video, I'm yet to go through the GoPro footage.
Excuse the bad camera zooming (friend doesn't know how to use phone camera apparently :P) and the commentating. The guys that run it often talk crap but it's usually amusing haha.
  • 3 weeks later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
