Fitted the wheels to the front today, pretty happy with the appearance, definitely keen to get another pair now though lol.
I realised just now that I only took one photo after putting them on though haha. I'll post some more later :)
I've also realised that I have much more room to lower the front now that there are 225's on the front!! :D
  • Like 1
Just got home from Bathurst from competing in the first two rounds of the NSW State Hill Climb Championship. Day 1 was backwards up the Esses, unfortunately it was raining all day which slowed the times a bit, meant I had a bit of fun though ;) . Day 2 was from Mountain Straight up to McPhilamy Park, luckily it stopped raining that night and after the girst group of cars the track had dried up :) . I managed to pull off a third place for my class both days, even though my car was still setup exactly how I drifted it (nice and stiff) and running stretched Rotalla tyres on the rear of the car haha. YAY two trophies for me haha. I will post up more pics and vids tomorrow :)
  • Like 1
I have to admit I was surprised seeing as it was a state level comp. I think I only managed it because I was (the tiniest bit) less scared of hitting a wall haha. Couple of videos uploading now so will post in the morning and will get some more uploaded during the day hopefully :)
  • Like 1
Here is an inside view of my fastest run up the Esses. As you can see it is quite wet so there is definitely room for improvement :P
This is an outside view of my smoothest run up top of round 1
Edited by timmy_89
  • Like 2
One last video. View from the outside GoPro on my last run.
The clutch smelt very bad at the end of the first day after missing third gear and then kicking the shit out of it trying to get the car sliding up the top haha. It started to smell again at the end of the second day, so I am definitely in the market for a new clutch before the next event. I've got a quote from NPC and have tried calling Jim Berry but have had to leave a message. Once I hear back from him I will make a decision on which of the two I will go with and then buy it and hopefully get it all fitted before the motorkhana at Easter :) . Other than that the car performed faultlessly all weekend which is great :D
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
