Hey guys, need some help.
I'm in the process of changing my clutch this weekend. The new clutch itself is fitted, but the rear gearbox seal was pretty fuarked so I was replacing it. It was pretty well stuck however, which I thought unusual, but I had to use a tiny metal pick to slowly pull all the old seal out. I finally got it all out, but the new seal won't go in. I have been reading for the last few hours but everyone seems to be like it goes in pretty easy, at worse, with a little firm tapping from a hammer. Has anyone got any suggestions of what I can do so get it in? I have tried hammering with a rubber mallet using an old metal pulley on top (exact some diameter) even with a metal pole on top of the pulley to allow more hitting room lol. I am going to buy a big metal hammer tomorrow in case the rubber mallet is absorbing the majority of the force, but does anyone have any suggestions why it is so difficult to get in?
Cheers
could sound stupid but is it 100% the right seal or going in the right side. Try some soap and hot water i guess.
My first thought was it had to be the wrong seal. But everywhere I look confirms it is the right part number.
I did try hot water firstly and then later tried with plenty of gearbox oil on the seal and the area it has to go into and still no luck :(
Well, to update, we managed to get the rear gearbox oil seal in, though I am not particularly happy with how it is. I think I am going to buy another new seal and pay to get it put in. We put the old oil in (which still looked like new) in case it leaked, and also because as mentioned I want to get the seal replaced again.
Overall the process of changing the clutch was not the most pleasant I have had. Everything was smooth sailing until we got to pulling out the old spigot bush, which we ended up having to break out carefully with a chisel. Got the new clutch fitted up, then decided it best to replace the rear gearbox seal (as mentioned above) due to it not looking the best. I think I know why that was now lol.
Once we managed to jam that in for a temporary fix to get me home, we set about putting the gearbox back in when tragedy struck again and my mate helping me put it in injured his arm. We stopped to rest and the pain started to spread down his arm so we thought it best to go to the hospital to get it checked. Turned out he flexed one of the bones in his arm (almost snapping). Luckily some rest and he will be back to normal. His brother ended up coming around after he finished work at 6pm and helped me lift it back on.
Anyway, after the eventful weekend, I got my car running again and started my 2 hour drive home after grabbing something to eat. Luckily, the 5 roos and 2 foxes that jumped/ran in front of me were avoided. Everything seems to be running smoothly, no leaks, but I will still get the seal replaced again and put the new Redline oil in at the same time.
Will take some getting used to the new clutch, but it definitely feels very solid! Will post some pics when I get the chance :)
Edited by timmy_89
Car is booked in to have the rear gearbox oil seal changed again, I'm really not happy with the one we put in looks. Will get them to put the Redline oil in at the same time.
I bought a decat for the car, turned out my car has a R33 cat on it..... so now I have to send this one back and get a R33 decat sent back. Keen to fit it up though.
Starting to get used to the clutch now after a couple of drives. Will keep running it in for a while, can't wait to give it a thrash though :P
ohhh I almost dropped a few tears of frustration it was probably cause I did it by myself on the ground but when a mate came over it was a better experience. Learnt a lesson that ill hire a hoist next time I do it.
This is my second clutch change for this car and both times I did it on the ground. Both times I regretted it, but I spent all my money on the clutch/flywheel :P
  • Like 1
I got mine done on the group and as a cash job for a workshop.
Finally had to get a professional to do it.
Set me back 3x the price of just the pro doing it in the end.
I did it the first time because I was on the absolute cheap, needed to replace the clutch before a motorkhana and picked one up for $250 on eBay. Lasted me a year though so can't complain lol. Did it the second time because I spent all my money on the new clutch and flywheel from Jim Berry haha. Overall for the money saved I can't complain, I'm just probably being anal about the rear gearbox oil seal and would rather make sure it's all OK. All that needs to be done is drop the tailshaft out so labor should be cheap to fix that part of it :) . Coincidentally, this is just before the exact same motorkhana this year haha :P
Hahaha nice
I was thinking that you had to pull the gearbox out again.
No wonder you sound so care free about replacing the seal again
Haha nar, not the rear main seal at the back of the engine. The rear gearbox seal where the tailshaft goes in :)
Martin knows because his found all his faults :whistling:
Ha!
Got your 34 yet Mani? Some things take time ;):P
Bah, it's frustrating but it's doable. Nothing says bonding like doing a pull-type clutch on the ground with a mate. Like goin through 'Nam together.
Car looks good Timmy!
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
