Trackschool Track Day @ Wakefield Park April 22Nd 2013
Bozman1
 Share
Hi Crew
Time to get another track day organised. Our last one in February was a sell out, and this one has less spots available
In summary:
*April 22nd 2013
*Maximum 3 groups
*Lots of track time
*Quality Instructors
*Lunch
*Free passenger sessions
*$250
Date:
April 22nd 2013
Venue:
Wakefield Park, 10 km south of Goulburn, is a purpose-built closed road track environment which simulates typical driving corners.
Price:
Retail is $265 per person
Forum Special
$250
THERE IS A BOOKING FORM ON http://www.trackschool.com.au
Track:
2.2km racing circuit.
Vehicle:
Use your own vehicle, or inquire about trying one of our Type R Vtec Honda Integras, or Nissan 180SX prepped race cars (extra charge applies).
Track amenities:
Ample car parking, canteen, coffee shop, carports, lock-up pit lane garaging, tower, timing and corporate area.
Price includes:
*Minimum 6 x 15 minute sessions
*Lunch in raceway cafe/canteen
*Experienced race drivers/instructors including John Boston, Ian Dyk, Tim Brook, Dean Evans and David Sieders. (Instructors may vary on the day)
*Theory sessions are held throughout the day for those who want it
Group organisation:
We only allow a maximum of 3 groups of cars for the whole day, with a maximum of 12 track cars in each group.
Drivers will be divided into groups according to speed and/or experience.
Clothing requirements:
Please wear closed in shoes, socks, long pants and long sleeve shirt.
Bring a helmet (helmet hire is available).
Cheers,
John Boston
[email protected]
0412 574 010
You can just get it on the day for $50 (at the Wakefield park clubhouse thing). Takes about 10 minutes. very simple process.
awesome thanks.
I'm going to ask the boss how he feels about me taking that day off ;) - he will probably want to come with me!!!
Hey guys I'll be in 100% if I can just book a place for me and pay the fees/ licence on the day at Wakie?
Can someone confirm?
I've been waiting for this event as I'm in beginer class.
Also what is the time schedule start time etc..
Thanks
David
 Share
    • I had a similar situation with my R32 GTS4. I replaced that solenoid, but it hasn't solved the problem. So its possible the pump is failing. It seems you need to drop the diff in order to do anything that might fix this. So its important to know exactly what the problem is. Or just replace / repair everything while the diff is out.
    • Yep, I was supprised. Its all about flow rather then housing size.  Doing G35-900 Vs ATR45SS-1 Next. 62mm V 61mm.
    • Of course sometimes you cannot go with the cheaper alternative but I try to weigh it up for the application - am I competing or am I going to the track ten times p/yr. As long as there’s enough information out there to back the cheaper alternative as a good option I’ll go for that.   I’m a bit of a bastard though as it’s my job to reduce costs, particularly on non income generating assets. EUR 500 saved for the diff + EUR 1,000 saved on BC racing over Bilstein and then say EUR 300 versus EUR 600 on an off brand windscreen versus OEM (for example) soon accumulates. I mean, I’m probably gonna put the car in the ditch anyway. Absolutely do not take this as a justification for always buying cheap shitty parts, just a rationale for doing your research and considering what’s necessary for your application.
    • All the above effort, time, swapping out parts in the dark (i.e. no O2 data). You're literally running in the dark.
    • Looks like both of my cars have pressure switch issues. The R32 GTR has 18 flashes on the ATTESSA controller which is "ETS pressure switch circuit". The 4WD light is intermittent, and often just restarting the car clears it. There is an $300 replacement option https://www.ebay.com.au/itm/285675135148?itmmeta=01HXN3YKRGKQ08GRZ5KFKKZWJT&hash=item428390a0ac:g:6CcAAOSwWxBltMEG so if it becomes a permanent issue and I can confirm that the switch is the issue, i have a solution. The NM35 is reporting C1208, and disconnecting the switch causes the 4WD light to go away. Translating from the Japanese shop manual "when the pressure is reduced to 2.6MPa (377 psi) or less: conduction occurs when the pressure increases to 3.8MPa (550 psi) or less: conduction is present. Reference: • Immediately after the E-TS actuator motor stops, the pressure inside the accumulator is high and there is no continuity." Not sure how good the translation is but from what i can deduce this means the switch is normally closed (NC) and as the pressure builds from 0 to 550 psi the switch stays closed, then opens and 550 psi. As the pressure drops from 550 psi to 377 psi the switch stays open then closes again at 377 psi. Is that how these things work? These pressures are a lot higher than the R32 ("control pressure 0-228 psi") but i'm hoping i can find a generic switch (like they've done for the R32) to use as a replacement. Maybe something like https://www.ebay.com.au/itm/355586397452?epid=1676016964&itmmeta=01HXN534AF22ACTG6TGDDQGEQ7&hash=item52ca99d50c:g:mAEAAOSw8ilmBcMh&itmprp=enc%3AAQAJAAAA8LtWdNlWHgyJ%2F3cbw25S2A1lde3qBi3fJii4T3lQavCz4kpqiD42SmBa4FocMvXCjcxiowHjb8vZ8%2BWxc53BkHv781tkStSnCDaenfGKC3bIp0keK20dfsn9LoPa3TfqaEmAydqqyKobgTdXsGGzsl%2BRjOVGuD8OIpOv%2B0wMl7aUtHg0iJtojbtzA%2BRS8Xfm8Ufjuvz4niwrqglAXFUbkL6J%2FGuHPeeECZhLBBN3iNM1Swl94Fv5zE95YK%2B5O6dxDN1ySNOjdMxkA8yaprbuwRHFQv1nlGh%2FWjekj6EUFR2%2FO4HTsoKtSAkY0Mj1w1uf1w%3D%3D|tkp%3ABk9SR6zFjKXtYw but with a lower close pressure, and thread adapter if required. Am i dreaming?
