http://www.skylinesaustralia.com/forums/topic/420178-guard-rolling-where-in-melbourne/
theres was a small thread on this not too long ago, have a look through there, theres a few options
Edited by alex182
I don't know about faultless; he is black afterall. But if that's the only issue I can find then I'd say he does a pretty good job.
he even adds the special service of painting ONE caliper.
just one. not any more even if willing to pay.
