So jenna and i like doing stupid amounts of laps at track day. But lack a running car
Generally the laps are not very fast, but very sideways
progressive laps times
wakefield 1.08 (jenna 1:13) (r888 rubber 270rwkw)
smsp south 1.03 (jenna 1:11) (r888 rubber 300rwkw)
pI 1:53 ( regularity so not pushing) (street rubber 270rwkw)
smsp brabham 1:44 (handcock c70 310rwkw)
SMSP north 1:08 (handcock c70 360rwkw)
winton 1:37 (jenna 1:49) (r888 rubber 300rwkw)
quick summary of mods
hks2530
hks dumps
racepace exhaust
HKS IC
flex tune
tein colovers
ikea arms
race seat
310rwkw
So I bought this car from a member on Easter Friday 2013
97 s3 gtr non v-spec so after 100k the vspec diff doesn't f**k out
This car has 110k on the clock ( nismo cluster)
picked it up from Melbourne from a sau member and drove it home(would recommend grant... Great seller)
air con is cold and shit.. Which is awesome
didn't buy it to look at it so tomorrow I will slap some brake ducts on, change the oil, bleed the brakes and take it to Marulan on Monday
I am not sure we're this thread will go but hopefully it will be a reliability test, and picks of me changing shit that has worn out vid of launches and laps of Jenna and I having fun
So anyway
29/3/13
The story begins
Compression
S1-165 s2-165 s3-165 s4-156 s5-165 s6-160
Within spec. Ill keep a running tally on this as it gets a beating
Car has the following mods
Shockworks Neotech Coilovers -
HKS Dual Dragger dump pipe back exhaust, awesome note.
Bosch 044 in-tank fuel pump.
600cc Sard Injectors
Apexi PowerFC + H/C
2860-7 turbochargers
Cam Gears
42mm Alloy Radiator ( chinas finest... I am sure this will be proven as junk soon)
Turbosmart E-Boost Boost controller
Overall for a 270 rwkw car it feels ok. Lost of black smoke on gassing it so may need another tune
first mod was to remove the ghay gear knob
old
new
Let the fun begin
https://www.sau.com.au/forums/topic/422630-fatz-gtr-reliability-testing/
anyway
oil changes( looks like it needed it as well)
coolant checked
brakes checked
brake cooling added
on the trailer ready to party
after 24 hours of ownership the single plate clutch is farken shit and need to be replaced
farken shithouse, rattly jerky pos
so took this out to the track, did about 140k's
really i should have got an alignment but there was no time
car seems quite laggy for -7 turbos (which i have a solution for)
the tyres on it are massively shithouse ( don't buy Bridgestone s02's)
pretty bad understeer then oversteer
rear hicas needs locking
lol
was slow but fun
then it had a misfire which after an hour of fiddling we worked out was fuel surge at 2/3 full tank (farken what?).. i am guessing the bosch has been installed incorrectly
needs an oil cooler
i was wrong on the fried rice radiator it performed well
anymore than ten laps and the brake fluid boiled so less shit fluid will be used
  • Like 1
It's strange driving a r33 although they are only 50 kegs heavier they feel 300kg heavier than a r32
I guess it is in the better build and stronger chassis
They also have less steering feel( on initial turn in)
Just my thoughts.
Although my r32 was 1400kg wet so this may be the reason the 33 feels so heavy
Nice mate. Wow how cheap is it to run your car at that track! Wonder why SAU havent organised something there. Great build mate will be interesting to see how long it takes to um streatch the reliability after your history with the RB's lol. Will definately have to take my 32 down to that track for shakedown once shes finished.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
