the tyres on it are massively shithouse ( don't buy Bridgestone s02's)
pretty bad understeer then oversteer
rear hicas needs locking
I said this on the first track day
After putting new rubber on the car I discovered one reason for the shit handling
The drivers side rubber was say 80% and in good nick but the passengers side was about 30% and a lot older( as in starting to crack as sht), this explains the massive oversteer on right handlers and good grip on lefties
First thrash of the new rubber and the car is much better
Even though I like to grab Neil's bony arse
I don't like men. So no ls1 ghayness
I wasn't going to give you an LS1... But Twin -7s on mine would be nasty... And I'm at the "Build the exhaust manifold" stage... :P
Awesome fit. Any rubbing???
Why a T04Z? What other supporting mods will you do, if any?
Car is almost stock height so no dramas... If it was lower the rears would need rolling
Was well priced
Supporting mods will be a r34 n1 motor( head gasket, pon cams and some injectors) and a e85 tune
Ill put some fancy oil in it so I have something to talk about at the pub
People say they are a little leggy... Mind you I have never been under 4500 rpm at the track
I have a set of hks Ss turbos in the shed I could slap on if I wishTo ladie boy
Pretty wheels on tidy R33 GTR... you've changed!
You know it
Looks tuff very nice
Still going e85?
Yea still Going e85
Just picked up the surge and pumps
Surge tank done
i asked for a quick drain valve on it as well so i can flush the e85 if it sits for two long
see if this work
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
