give us the info son!
+1
Custom diffusers and under trays interest me...
Looks good
Custom?? Or off the shelf??
Sitting down ladies you have three options
1: dry carbon front lip and dry carbon undertray $1500
2: dry carbon front lip and Frp under tray $1200
3: Frp lip and under tray $900
Parts coming together for the new engine
Cheers to god12a on fronting up the good( Tarmac solutions)
No I can plan my super mega hyper excellent catch can system
Dash ten on pasengers side
Two dash 12 on the drivers side, angles and spaced so as not to hit shit and be able to tighten the f**ker up
Baffled and shit
[url=http://s236.photobucket.com/user/fatzgtsr/media/pete%20gtr/s2%20r33%20gtr/image_zps52ed1d07.jpg.html]image_zps52ed1d07.jpg[/url
Plan is to run a electric oil pump below the air filters that's triggered by the haltech when over 6k rpm and a set boost level, this will suck from the nismo catch can to the passengers side dash ten
Then a dash 12 vent to the oil cap
And a dash 12 drain from the second oil tank
Are they gate hinges?
Stainless door hinges I thought lol
sooo you ladies dont like my flaps?
lol
super jealous of catch can system (stupid East-west engine), I read back a few pages and cant find detailed info on what the setup will be
lucky for you i knowcked up this awesome diagram
i do belive it will answer all questions
on the potential awesomness of my proposed system
catch can.pdf
attachicon.gifcatch can.pdf
Thanks. As complicated as an oil cooler setup with filter relocation kit lol
Will look into getting an electric oil pump for mine too
Yea hook me up
You shorted your issues?
I've got fittings welded to the sump, I'm just going to let the oil drain back and do its own thing *fingers crossed.
Turbowerx pump cost me just under $500 delivered, flick me a PM with an offer I can't refuse :) It comes with -6 AN in and out fittings but you can get others if they are too small/big.
http://www.ebay.com.au/itm/151158789695
Edited by SimonR32
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
