Yeh, when I first went for a ride in a car with RPM modified Teins I went out the next week and bought some and sent them off to RPM. They are damn good things and suspect its all in the valving more than the spring rates.
Had to grab a second pair when I went GTR rear cradle and got the chance to do another set...largely the reason why my thing even as a rwd car cant blazed 2nd gear with 330rwkws...just traction and hooks up!
What sized rim are you running? Thought of throwing some Carrera Cup slicks at it?
yea they sell themselves these shocks
awesome!
run a 10.5 inch rim
i have thought about the slicks but have been too lazy to put some on
Come to my joint
Bring six pack
And you can have a look while I drink beer
Will do. How far is your place from WA?
Struggling to understand why the F/R rate differential. Should hook up with that soft a rear spring. Just worried youd never get on the gas because of the front rate?
Why the rear is a lot softer than the front? You need the car to squat to get the power down.
No you dont. Not in a GTR on the track. Maybe for drags and maybe for rally style stuff where you cant carry all the corner speed that is available but not for the track. The thing that kills you is understeer, not lack of traction. A large F/R spring rate differential makes the car push.
ill ever get a alignment for the next track day and maybe adjusted slightly to take into account my 140kg girth
You've slimmed down?
New filters in still missing
Compression test showed 160,158, 150, 138, 135, 160
Ill try some new plugs and coils just to make sure then it's off to dvsjez to have the fuel pressure checked and protection added to the haltech
Might be time for the new motor
So this pos is now booked in to Jez to get some new engine love on the 18th
So hopefully it will be back with additional compression
New engine has som e cool shit
big sump
front lsd
hks 2530
port match manifolds
hks dump pipes
some cams
cam gears
nizmo plenum
Hks ic
Ill also get the egt sensors installed and some fuel pressure protection
Then book it into a few track days
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
