Yup, I'll be bolting on my super grip magic rubber that takes every last bit of skill out of the equation, and pretty much makes my car a F1 car.
Run what ya brung Aggro....
we cant compete with your tricks slick
You are entering ?
Redemption for the poor 32 :D
yeah ill be there, car goes ot unigroup on the 1st to get fixed.. as long as i beat fatz and come 2nd ill be happy.. Cant catch that fkn 35 though!
The can on top of the motor, have you done anything inside of it or just fitted the AN fittings on front ?
I have the same can on my 34 which I'm going to fit a baffle into and put AN fittings where to hose barbs are then run hoses down to a Hi Octane washer bottle/catch can then back to the two factory pickups
35 won't be there he is bringing the vette
Very elaborate catch can setup
Should work well for track thrashins
yea its been a slow work in progress this setup (this is version 3)
its just a regular catch can with an bungs welded on
in its current spec it works a treat
its also got the electric oil pump for when the engine gets tired and needs some more help with breathing mods ( which is activated by the haltech)
engine bay is all speed flow with speed flow hose
no dramas putting it together just lube it up with spit and ya finger ( like most things in life)
fuel setup is a yank brand as it would have been a 3k exercise in speed flow (earls?) not sure jez did the fuel setup
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
