Sorry for the complete noob question but I wanted to be sure before I ordered them and can't find an answer on the site. I have a 2003 m35 250t rs4, are these the right model numbers for the QFM A1RM brake pads:
Front: http://gslrallysport.com/au/qfm-db1232a1rm-brake-pads.html
Rear: http://gslrallysport.com/au/brakes/brake-pads/db1509a1rm-qfm-a1rm-brake-pads.html
thanks! :)
Are you tracking the car?
A1rm are a light track pad. For street go for their HPX pad, and just ask for 350z NON brembo pads. Job done. Gsl rally sport are good.
Is there any disadvantage to getting the A1RM pad if doing little to no track use (other than cost)?
They will go through your rotors quicker, and will be less effective because you won't get them hot enough to be in their optimum working range.
If you are getting pad fade with HPX then you need to take it to the track. Remsa are also ok I've heard, and gsl are moving to them.
The REMSA's are brilliant; gsl reckon they're halfway between HPX & AR1M on temp range ,but nowhere near as hard on rotors as the AR1M.
No squeaks or shudder, just dusty.
I like 'em that way.
I'll be testing out the a1rms on the 180 on Tuesday. I've got a full set of them in, they need a good bedding in which I might do on the way down to Wakefield.
Should work well on a lighter car. I did have pad fade from the hpx on the track in the stagea or whatever be got in the back. To be expected after I purposely put some hard stops into them.
Everything above about A1rm's is correct. I really need to get them off mine, lots of dust , poor feel until I get some heat into them and I hate to think what they doing to my discs. However, I was very happy with the one track day I did. ( 10 min sessions at Marulan ).
Give GSL a call and be honest about what you want from your pad. If it is just for the street, just get a street pad.
Thanks everyone. very helpful advice, steered me away from a terrible decision! Ended up going with the HPX pads all around so hopefully they are as good as you all say haha
:cheers:
The HPX is a good daily/ fast road pad; just make sure you follow the bed-in instructions closely.
People seem to go bananas when bedding them in; overheat them and they squeal like a bitch. There is no need to do tonnes of stops from 100+km/h!
I did the ones on my missus car at no more than 60km/h in back streets, and they are quiet as a mouse; with great feel. Bugger all dust too.
GSL Rallysport are great to deal with as well; they had pads & rotors to me (Blue Mountains) from QLD, IN ONE DAY!
My HPX are squeal free and good feel, but dusty as all hell...
Must be the slotted discs making them do that... :whistling:
Less than 24 hours to me 45 minutes east of Melbourne..
I have hpx they stop awesome and virtually dust free. Mine do squeal like hell but maybe I didn't actually bed them right after what dale said
Shims are most important. Anything is going to squeal without shims. If they aren't installed properly, even in the slightest, you'll get squeal.
Every QFM pads have bedding in instructions in the packet.
Yeah I have learnt the hard way before.<br /><br />The advice I got from gsl was anti squeal paste between pad and shim - but not between shim and piston.<br /><br />Do you agree? <br />
It can't hurt.
I've used the stuff before, and had squeal, not used it and had no squeal. When you have the pads out, give them a small scrub on a concrete surface to take off the sheen. Helps them bed in a bit more.
Well i have put it between pad and shim, and on the other side of the shim also. I understand it just to be an insulating barrier, it doesn't stick or hold anything together. <br /><br />Will bleed them up and start the bed in process as per instructions. If they squeal I will be pissed. Ok on a tough stripped out racer or street car with one thing in mind , but on a luxury gt like a 350GT - ain't nobody got time fo dat!!
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
