hi -
Pulled off my CAS to diagnose a no start problem and discovered a half broken splined shaft in it. I tried spinning the CAS shaft by hand but it seems siezed hence why it broke the spline.
I had a look with the torch inside the exhaust cam where the CAS goes and noticed the other side of the broken spline shaft. I tried picking the broken piece with a pick tool but it wont budge.Not sure if it can.
Could someone pls explain if that splined shaft is part of the Camshaft? Cause it doesnt appear part of the CAS. how do i replace it ?
I hate to cough up on a new cam.
cheers
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/
840857_B5_7_DDF_4_C47_A293_BB7_D565_D231 FCAE778_C_ACC7_4_D64_B7_CB_625_ECEF37256
Looking into the exhaust camshaft. You can see the broken bit.
1138_B1_BB_8_CDA_418_B_B0_DA_9_EF94_E80_ D8_F97962_03_D4_4_D78_95_B7_E56_FEF6_C7_E45_FF45_F_24_FE_4923_BA2_E_724357_CCD44
first pic is the birds eye view into the CAS. You can see the broken half moon bit inside.The broken spline shaft piece which came out of the CAS
5_B5803_B9_36_E4_4_C3_E_A88_E_461_AF39_DF6_FA092_E_9282_488_D_9_FF3_921_DFFC13_F DCA4375_A_76_F8_46_FA_B606_FA1_E7_B8_E08
..The biopsy. A lot of red dust from the seized bottom, bearing after finally turning it using the vise.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6817017
Looks like you've broken the spline off the cam. The CAS spline is supposed to be female with a half moon that matches up with the male spline and half moon on the cam
cheers. So that means a new camshaft?
ps: I've posted a Wanted ad in the Forsale section for anyone that has a R32 - RB20DE camshaft and CAS. pm me if anyone can help.
Or if anyone knows where i can pick it up in melbourne.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6817506
might be a good oportunity to swap out the motor for something better, if you cant do the labour yourself then you are up for a fair few $$$
I'll be doing the labor myself unfortunately. Otherwise yeah i would consider a swapout.
I have a pair of standard RB20DET cams, which are a slight upgrade over DE, and a CAS if you need.
as long as i dont have to pissfart around with the valve clearances and electronics, timings etc...
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818074
Because they both use Hydraulic lifters there is no adjustment for the valve clearances and because the spline/drive on the exhaust cam is the same the CAS are the same.
The DET cams run eight degrees more duration on the inlet and .5mm more lift on the inlet. The exhaust cam specs are the same as the DE.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818210
you will have to pissfart around with camshaft timing and retension the timing belt-you are doing all this with the motor out?
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818401
I guess i was trying to say I need a drop in fit. Putting something non stock for the engine gets me concerned a little with having to mess with other stuff.
This is my friends car and she is on a limited budget. Trying to do it as good and inexpensive as possible.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818511
fair enough, i see where you are at, remember when it comes to cars (especially skylines) "good" and "inexpensive" are mutually exclusive terms
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818841
I hear ya. I own an Alfa Romeo and an old school Ducati. I know the story line all too well with the exotic.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6819236
You don't need the keyway in the cam I ran without for 3 years 400+hp no problem. They just need to be lined up in the right spot again
not sure I understand this. I believe im missing more than the keyway in the cam.
check my first two pics
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6820431
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
