  • Replies 42
The figures I read must have been old then, explains some of the 30KW gain from a slightly smaller turbo between the BF and FG. Im trying to look after this car so wont be reaching this overtake mode for a while, im interested to know more about it. Also Launch control wont get a workout.
Overtake mode works that from around 70KM/H if you open the throttle up completely, it'll add in an extra 10% of Torque for 3 to 5 seconds. I'm not sure if it's in the autos only or not though.
1710kg is hardly near 2 tonne. Afik the 33 is approx 1370 so 340kg is a big difference but unless you have driven one you just see numbers. Aaaaaaaand your 33 gtst didnt come with Launch control. I love skylines and it disappoints me (on the skyline side) at how good the XR6T's are without any mods. I guess thats why Ford designed and built them like this, to challengebto Import market.
Not a chance.
Plus if your car is still on stock boost, even a N/A FG XR6 will almost keep up from on traffic light GP.
Straight line acceleration wise, stock R33 is no longer fast versus many of the large family sedans we have on the market.
Edited by Mayuri Krab
Not a chance.
This^
I'm even confident enough to say a stock V6 camry will keep up with a stock r33 gtr.
Not a chance.
A bog stock FG XR6 is quicker than a R33 GTSt, my mates one ran 14.4 @ 98mph. No mods what so ever.
My old man had a similar race before
His GT35R powered R33 at 350rwkw vs a BF XR6T at 330rwkw. The skyline hosed it from anything including roll ons at any speed and off a standing start. For the mods listed in the OP though the XR6T will win without trouble.
I was getting rolled by a FG XR6 turbo automatic ute and sedan at the drags, running low 13's everytime. Also sat in a mates FG XR6 turbo with a full exhaust and the thing has so much grunt down low, its pretty impressive.
Overtook a BA XR6 turbo one day starting at 3rd position on the grid (behind him at the lights), he had a few passengers and i had a boosted stock turbo..
Not sure about that one...
Unless you mean the current Aurion (Sold as 3.5 V6 Camry in other countries), those were faster than most 6 cylinder falcdores in a straight line I believe.
The older (3.0) V6 Camrys had pretty 'meth' acceleration espeically if they had the ancient slush box auto, my parents had one (2002 model) & overtaking at highspeeds (80km/h+) sucks major donkey kong ballz.
you blokes are dreaming, I ran high 12's with nothing more than a zorst a tboost and a safc. The old skyline with very minimal mods in the right hands can dust the ford no probs.
Obviously the henry has potential for more power with the cubes but dont under estimate weight, the henry is some 3/400 kg heavier than the line.
do the same mods to a xr6t and they will be in the low 12's with a decent set of tyres. it's all well and good to say a car with mods will beat a stock car, but that goes both ways. a modified xr6t will just be a pair of tail lights off in the distance when racing a stock skyline.
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
