It's what's in the heart that counts. It's like moving Leon from Packenham to Toorak. He'd still be known as Leon from Packy.
I went to a house party in Packy the other day. The guy hosting it knew who Leon was. He's a local legend.
  • Like 1
Guys we need assistance
If you have friend a or 2 coming up with you and they could lend a hand that would be fantastic.
Link below
Cheers Wayne
http://www.skylinesaustralia.com/forums/topic/424957-deca-officials-volunteers-1st-june/
New diff is working awesome, though last night it started stepping out when I put my foot down in 4th on nepean hwy heading home. Still getting used to not single spinning everywhere :P
What are lock stops?
Why were you stalling? Just rip the hand brake and keep your foot to the floor :P Braaaaaaappp!
(for some reason) my car had/has a ridiculously small turning circle. I suspect it was rubbing on the inner guards and bogging it down when on the skidpan at speed. Anyway, it wasnt a happy chappy and my handbrake skillz need work too haha
Because the new suspension has external canisters, we were concerned the steering angle might cause the wheels to hit them. So we installed lock stops inside the steering rack to limit it.
Link below
Cheers Waynehttp://www.skylinesaustralia.com/forums/topic/424957-deca-officials-volunteers-1st-june/
Ok
It's serious time..
We need people to help run the day. What I'm looking for is for volunteers to help run the morning events .
We have the
Skidpan.....need 3 people
Mini..3 to 4 people
Long..5 people
At this stage there is only Anna and myself..
So if you have mates/ girlfriends/ boyfriends / mums or dads coming up they will be helping out ..
If they don't want to help out leave them at home.
Cheers wayne.
  • Like 1
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
