A fire extinguisher is required by all entrants and needs to be bolted to the vehicle. Screws or cable ties are not acceptable.
While everyone is getting their cars ready this weekend keep this in mind. People have been good lately but since we have a few newbies this is worth highlighting. Please use bolts.
Another thing worth mentioning is check your engine oil!!! Last Deca we unfortunately had someone ruin their engine due to not having enough oil. Dont let this be you.
4 Hayley Stapley 180sx
5 Bec Pretty Mini
10 Karen Caruso Mini
11 Juliette Remfrey BRZ
30 Paul Stephenson 34GTR
31 Ekat Evo7
Wow! A new Record!!
6 girls have entered!
How do you feel about being beaten by a girl??
  • Like 1
Hey guys can I be changed to the 180sx.
Sorry for late notice but the car is ready and has been to the last 3 deca events with this club.
If I need to pm someone then let me know.
Oh no josh, i geuss this means the r33 isnt fixed :wacko:
Thrash day for the 180sx it is! lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
