I've searched, but not found.
About a year and a half ago I remember a bloke on here (from nz rings a bell?) was asking for help on making some steam pipe manifolds for sr's & rb's. he made a few and sold them here priced at about $400 from memory...
Can anyone link me?
Cheers
http://www.hybridperformance.co.nz/hp/
probably easier navigating on his site.. but read carefully... on these forums before committing
Why you say this? Out of interest...
All i can find is that the are not perfect flat, and putting the Bolts in is quite hard on on the low mount version.
But for that price....taking it to a machine shop and flattening it seems like a pretty good deal to me.
( others say its a ebay manifold just "redone" )
Customer service is a very big thing in today's world. But some times I can understand why. Some people expect everything for next to nothing. As what was said before. ITS A $350 manifold. What can you really expect Go get it machined for $50 and bobs your uncle. Bolt it up and away you go.
well i already planned to get one knowing the issues.
The price + low mount to me = win.
Ill be getting the low mount External gate, i will then get it machined.
be sure to take photos :)
I'm still tossing up between 6boobies or Rex Kelways or ETM or Hybrid Perf
^ thanks
The saying 'you get what you pay for' rings true with everything to do with cars... No surprises, but for $350-$400 seems good.
Having said that I've just seen the Rex kelway thread in NS, now to enquire about the cost
Edited by s213b
I would prefer nothing if it means dealing with 6boob. Customer service goes out the window if you ask for anything custom.
There are hundreds of fabricators around the country that could make a decent manifold but none that can do it for $400...
Rex Kelways does sex work in terms of manifolds. he's willing to customise anything you want... twin scroll, with 2x outlets merged into 1x etc.. but because his work is sexy, it's expensive.
I'm still tossing up with manifolds (thanks to Mr Tax man, my turbo upgrade money is going to him)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
