Hi all,
Just a small annoying problem with my baby
When driving I get a total "miss" every once in a while
It's like engine stops for a millisecond and then continues fine
I have tried to find a pattern but there doesn't seem to be any
Can be any speed, any gear, just random
I am thinking maybe fuel pump?
Any ideas
Hey mate mine does this too, usually when I've backed off the throttle at low revs then as I start to build revs again can get a miss. Only in 3rd or 4th though, and not very often. I thought I read somewhere on here that it was a common thing for RB26s so I wasn't too worried; car runs great otherwise :)
Hi all,
Any ideas
Are you by any chance running a Power FC?
No its with the ecu itself I think. Not much you can do about it. Apparently some people doesnt have it but most do, Some tried checking the earth/ground but doesnt really solve it issue.
I have that issue too and its mostly during cruising. I was told by reputable tuners that it is common will not cause any issue.
Thanks Brandon
That puts my mind at ease
Was wondering what would happen if it "missed" at WOT at 8000 revs.
It seems to only happen (or I notice it) at cruising revs
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
