Can someone please confirm nm35 suspension (shocks) front and rear part numbers. I think in this it states 350z premium is compatable.
Fronts won't work for AWD because they have a different bottom as they don't have to avoid a driveshaft. If your car is RWD they may fit.
Rears should fit, but front deff wont.
The G35x is closest to our car for AWD purposes.
Edited by M35woah
I don't even think the rears will work; don't they run a true coilover, rather than separate coil/shock?
The reason M35's run them separately is to allow a flat cargo floor with no intrusive strut towers.
Sedans & coupes have no need to do this.
Yep, scratch my last comment; but the shocks on 350Z & V series look to be quite a bit longer.
Agreed Scotty, for the price of a set of KYB shocks; you're 2/3rds of the way to a set of BC's.
And they'll sell you a replacement damper for $100ish is you ever need one.
In cabin pollen/AC filter.
Nissan part number 272774M400
Ryco PN:RCA113P
http://tygarbyte.blogspot.com.au/2012/10/m35-stagea-air-con-filter_6431.html
Has anyone changed the A/C cabin filter ?
Also what filtet/part number did you use ?
Bugger... today my M35 developed a major slip in drive. Ok in reverse. Anyone else have this problem.?
Who has an auto for sale in syd ?? Might be a quick fix, till i can see whats wrong with this one. It's the family daily drive..
Edited by FIA510
^ Dude - wrong thread for that question. Start a new thread.
I used Ryco PN:RCA113P to replace my cabin filter. Old one (a bosch) was rank too.
There's also a Ryco with a C at the end of the p/n which designates it as an activated carbon/charcoal filter, this is the correct replacement for the factory one.
I'm wanting to bag my 2002 M35 and was wondering if a 370z airbag kit would fit? Reason being it's impossible to find a specific kit for a Stagea and I don't wanna go down the custom route because it's gonna be EXPENSIVE! I considered coilovers but it's gonna be stupidly impossible to drive on normal roads and over speed bumps with the height I want. Any help would be appreciated, cheers.
Doubt it.
There are bag kits available for the M35 Stagea in Japan though.
Best bet would be to look on Import Monster or contact Jesse Streeter
  • Like 1
This is your problem, so why be stupid at all?
The crossmember is the lowest point, I wouldn't want to hit something solid with it...
Doubt it.
Nothing local, but yeah IM or Streeter can sort this one out for you http://page4.auctions.yahoo.co.jp/jp/auction/d148045989
Depends on your definition of 'expensive' too though.
I contacted import monster before posting this and they advised me of a couple of airbag companies, sadly none of which had an M35 kit. I only want bags so I can drop the car while parked, 19x11's and 19x10's would look good with coil-overs but when I want to drive away I wanna have a comfortable ride without getting stopped by the police. The only kit I've seen for an M35 was $5,700 Aus and that's abit excessive just for suspension in my opinion.
Wish I could read Japanese, it would help with a lot of things.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
