  • 5 months later...
did the hill climb. was a blast. total handful....
up in the air of what to do.
theres no low to mid range then huge top end for a second and change gear.
do i change the rear housing from a .82 to a .63 rear housing?
or wait till i put a 25/30 in it and hopefully that fixes it?
Before spending money unplug vct solenoid and see if it makes things worse. If it stays the same get vct workimg
yer im going to have to.. just irritates me i have to do that after sending it to 2 different workshops, when i suck at mechanics!
http://s1196.photobucket.com/user/adz2332/media/Mobile%20Uploads/received_10208902650220669_zpsigtbb7kk.mp4.html
video of the hill climb...
doesnt do how steep and tight the turns were justice! plus its barely a car width wide!
  • 4 months later...
Bit of an update.
Decided to paint the car. currently in a million bits. Have an rb30 also half pulled down.
Asked around, what is the biggest stupidest wing for a 33? BCL was the answer..... as you can tell my dad in the back ground was as impressed with it.... good for a laugh!
13557911_10157144131195215_3409995096213
13626637_10157144130440215_8579717224417
Prepping
13627160_10157140331440215_8641202146681
My brothers r31 but its the colour im also doing my r33. hard to get a good pic of it in the shade
14203217_10157431310855215_2974133742019
14212109_10157431310665215_7376160523224
Soo as for the interior, i let my much younger brother loose to decide the colour.... he came back with the phantom purple from the falcon BF era i think..... I didnt care so i said go for it. sprayed it on the under side of his boot.... and the result was
14212661_10157431104530215_3209309104960
I didnt mind it to much.... but he said its not finished and i had to go away until it was done.... i then come back to this
14191893_10157431104635215_2434744404366
14212176_10157431104750215_2695265642969
Im unsure how i feel about this... but hes adamant that its what my interior is going to be.... not only that its all been bought! lol Leason to you all dont let your younger siblings pick colours!
  • 3 weeks later...
57 minutes ago, Dose Pipe Sutututu said:
Don't go 0.63 rear, yuck.
I was defiantly considering it after seeing a s14 with almost my exact same mods on a rb25 make 280kws, and boy was its acceleration excellent and response was awesome.
But im building a rb30 / 25 so hopefully that will put the response issues to bed
14519923_10157584623275215_7006899475110
14606348_10157584623385215_3686929384467
  • Like 1
Thanks mate. im happy with it being my first time doing it. theres a couple things ill touch up and fix after next weekends oznat thingo.
And if anyone is in adelaide and is going to the oznats, ill be there in this and my torana. plus my bro in his 31 (same colour) feel free to say hi!
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
    • Yeah I spent close to a year finding one. I was even tempted to buy a RB25DE N/A head and port it out. That latter option, could still be an option.
