Hi guys,
I am planning a 2530 into my S2 RS stagea (rwd, neo)
Now heres my dilemma. It is my daily, so need to be able to do an engine swap in a weekend, so cant pull down my engine to do it.
I have bought an RB30 and a non neo RB25de to use the head.
The plan is to put the neo inlet manifold onto the head, due to injectors, sensors etc.
The thing is I know the neo exhaust valves are bigger, so how much would using a non neo head hurt the power?
I am not after huge power, currently making 285 with a GT3071 and will be using the same turbo. Looking at improving drive-ability and torque.
I have searched like mad but cant find an answer.
So has anyone put a non neo rb2530 into a car that had a neo, and what was the outcome?
Thanks
Ben
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/
Thanks. it is an r33 head.
The issue with using my head is the time it is going to take to have to weld up oil feed and run external line.
I have a Nistune and am running ls2 coils so ignition wise no problem.
I am leaning towards using my head, will just need to wait a while as a result.
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6888231
Neo head is far better...you'd be silly to go backwards..
what about 25/30 height difference, i thought(maybe wrongly,i havn't done it) that you have problems with manifolds
due to extra height? can you use standard inlet and ex manifold?
where did you dyno your car?
cheers
darren
Edited by jet_r31
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6889429
Thanks guys, thats what I thought!
And no joke about no matter what it wont be ready in a weekend, I was deluding myself for a bit there.
Just wondering if anyone knew from experience, but I suppose people dont normally try a backwards step to see how bad it is!
Edited by superben
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6889432
cheers
darren
Hi,
I have roughly checked the height issue, and it seems all good. Was planning on triple checking soon, there is always the option of dropping the engine a little to gain more clearance if needed.
Car was Dyno'd at Garage 7, plus I bought the nistune individual licence and already had a wideband data logger.,
Tuning seems pretty good, at cruise and WOT, but there are some heaps rich spots around 3/4 throttle to tweak. Its the VE map thats doing it.
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6889813
If someone can show me a NEO head out perform a non NEO head for power and response on the same motor ill eat my shirt.
The only advantage I see with a NEO head is the ability to use bigger cams while retaining VCT, all other differences would be hard pressed to see a change on a dyno.
Use what you have and save your $$$.
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6890436
What are you showing me exactly?
Spend a few grand on any head and it will out flow a stocker.
What I am saying is by bolting on a NEO head over a non Neo head you are not going to see something magical happen power and response wise.
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6890451
that's just like saying leave the single cam head on, because with double cam u won't c improvements in power and response
Everyone knows if u can retain VCT, it significantly improves bottom end response and torque
but since he has the non neo head already then it will still get the job done
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6890462
You are comparing two TOTALLY different heads there mate.
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6890465
youd be safe as you know its not going to happen..lol, i bet on a 150mph car there would be,maybe not the small shit though
cheers
darren
Edited by jet_r31
https://www.sau.com.au/forums/topic/426681-neo-head-or-not/#findComment-6890699
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
