Haha and im just a sales man.
Engineer sounds lenient. Im doing a rwd rb26 swap in my sedan and will need it engineered
Iv actually emailed this same engineer before I saw any of this a few days ago now for my r31 with an rb25 in it. He's in braeside somewhere I believe. Will see what he says soon hopefully, I'm in the same boat as you.
Started on the radiator it's a HQ ebay radiator with a fan shroud I made to suit twin 12" spal fans and I moved the bottom outlet.
There's about 6mm between the power steering pulley and the fan.
Also mounted the 45mm turbosmart hyper-gate and tacked up the dump pipe. I'll finish the dump pipe when I get the flex
coupling that will be cut in the 2" tube after the wastegate.
Welded up the intercooler and piping and also fitted the synapse diverter valve which will be plumbed back to the air box.
Also started the chassis strengthening using 89x89x3.5 rhs shaped to suit the floor pan.
That poor Torana! Will be interesting to see what it weighs with all the Nissan gear in it - I'm betting it will be less than the R32. Can't wait to see the final product - great project turbo76lx!
wow, your fabrication skills are sensational!
No doubt you know your stuff!
Given your torana is 25+ years old, why not go club plates which will give you 90 days road use a year?
You obviosuly know what your doing and are bouncing your approach off engineer before application, club reg would allow you to bypass expensive engineering approvals and get you legal road use for under $200 a year.
I love old Torana's and Skylines so what's not to like here. So this will definitely be interesting once complete, to see how it handles. It ought to be a farking hoot to drive whether it handles like a Skyline or not, but I wouldn't be surprised if you find it holds the road in corners pretty good, with a nice drift every now and then when you want it. I wish I had your skills to bring back cars from the dead. I see plenty here in tas that need love and attention, but they just sit there rusting away.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
