It's more to do with the fact that the shocker mount were never designed to take the weight of the vehicle.
Now that the coil overs are mounted to this spot I have just added extra bracing to transfer the load back to the original spring pocket/body rails.
Got some suspension and other bolts zinc plated and picked up some inner and outer door handles.
Sent Bonneville Consulting and email tuesday but haven't heard anything back yet.
Started fitting the back seat, needed to modify the seat base to fit over the skyline tunnel.
I used the seat base out of a UC hatch that I brought for spare parts but it may turn into a future project and wont need a
back seat. ( S14 front suspension, R32 rear suspension, drift ute, maybe)
The wire frame was a bit bent so it had to be straightened and reshaped over the tunnel.
Rigged up a hot wire to cut the foam.
All fitted up, I will probably only register the hatch as a 4 seater as there isn't mush foam left in the middle seat.
  • Like 1
  • 4 weeks later...
Gave the drive shafts a clean up and some paint.
Removed some of the lip on the fire wall and fully seam welded it.
Added some more strengthening to the front suspension towers to make sure the load is transferred back to the rail where the original subframe mounted.
  • Like 2
  • 4 weeks later...
Have contacted a few engineers to see if they were interested in taking on the project. I've chosen one, now I have to reassemble the car
so he can see where it's at and where to move forward from here. Hopefully he will look at it in a few weeks.
  • Like 6
  • 3 weeks later...
Had the engineer, Peter Turner http://www.techedaustralia.com.au/ have a look at the project.
He is happy with what has been done, he wants an extra brace between the rear suspension towers and I
have to have retractable seat belts for the outer back seats. The car will have to pass the IM240 emission test
and also have a torsional rigidity test. The plan now is to get the car ready for the torsional test then
start the panel work.
Rear seat belts something like this.
  • Like 3
Decided to mount the seat belt reel besides the back seat so they don't stand out as much.
Ground up a piece of flat bar to match the shape of the panel.
Will also weld this comp plate over the outside when the engineer gives me the ok.
Also made up some panels for the back out of some aluminium that i'll cover with some vinyl.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Started fixing the rust in the tail light bucket.
First had to get dogs ok on the tail light bucket from the spare parts car.
Only going to replace the bottom half but had to do a small repair first.
Had to repair some rust in the corner.
Bottom replaced.
  • Like 6
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
