It's more to do with the fact that the shocker mount were never designed to take the weight of the vehicle.
Now that the coil overs are mounted to this spot I have just added extra bracing to transfer the load back to the original spring pocket/body rails.
Got some suspension and other bolts zinc plated and picked up some inner and outer door handles.
Sent Bonneville Consulting and email tuesday but haven't heard anything back yet.
Started fitting the back seat, needed to modify the seat base to fit over the skyline tunnel.
I used the seat base out of a UC hatch that I brought for spare parts but it may turn into a future project and wont need a
back seat. ( S14 front suspension, R32 rear suspension, drift ute, maybe)
The wire frame was a bit bent so it had to be straightened and reshaped over the tunnel.
Rigged up a hot wire to cut the foam.
All fitted up, I will probably only register the hatch as a 4 seater as there isn't mush foam left in the middle seat.
  • Like 1
  • 4 weeks later...
Gave the drive shafts a clean up and some paint.
Removed some of the lip on the fire wall and fully seam welded it.
Added some more strengthening to the front suspension towers to make sure the load is transferred back to the rail where the original subframe mounted.
  • Like 2
  • 4 weeks later...
Have contacted a few engineers to see if they were interested in taking on the project. I've chosen one, now I have to reassemble the car
so he can see where it's at and where to move forward from here. Hopefully he will look at it in a few weeks.
  • Like 6
  • 3 weeks later...
Had the engineer, Peter Turner http://www.techedaustralia.com.au/ have a look at the project.
He is happy with what has been done, he wants an extra brace between the rear suspension towers and I
have to have retractable seat belts for the outer back seats. The car will have to pass the IM240 emission test
and also have a torsional rigidity test. The plan now is to get the car ready for the torsional test then
start the panel work.
Rear seat belts something like this.
  • Like 3
Decided to mount the seat belt reel besides the back seat so they don't stand out as much.
Ground up a piece of flat bar to match the shape of the panel.
Will also weld this comp plate over the outside when the engineer gives me the ok.
Also made up some panels for the back out of some aluminium that i'll cover with some vinyl.
  • Like 3
  • 3 weeks later...
  • 1 month later...
Started fixing the rust in the tail light bucket.
First had to get dogs ok on the tail light bucket from the spare parts car.
Only going to replace the bottom half but had to do a small repair first.
Had to repair some rust in the corner.
Bottom replaced.
  • Like 6
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
