i too am looking into getting tune done on my r33 gtr am running tomei reytec ecu. software is in english . has wideband and datalogging etc. any suggestions who has any experience with these ecus. i have put a run in tune myself , very easy to operate...
I'll need more than 1 to curb the depression!
More beers it will be then, Man that thing should be making close to what it is on E85 on pump fuel with the right tune.
Mine only has:
Unopened Engine
Apexi Power FC
CAI BOX with Pod
Yellow Jacket Coil Packs
Z32 AFM
3" Turbo back + High Flow Cat
660cc Injectors
Bosch 044 Pump
Hypergear SS1PU Turbo - 20psi peak fading to 17psi (I need to set it to hold boost @ 20psi then it will make 400, ran out of dyno money to dial in the EBC to hold pressure)
That is what got me the 377hp on 98.
Speaking of signing up will be as soon as my gtr lands !!! Wanted to know is there any other track days or happy laps events that happen other than the ones that are on the 2013 agenda as I work away from brisy and 90% of these days are on my days away with work which I am spewing about !?!?
Hey mate,
The calendar has grown to be more of a rough guide as to when events are. If we have our way, there should be a few more track days coming around. Our aim has been to have an event each week so that people, such as yourself, who can't make it to one can make it to something else. With timing on these things, it does come down to QR and when they can let us use the track but we have strived to have a happy laps sesh every 6 weeks. Usually, a few weeks before the end of the month, I will post up events for the upcoming month. All of these will be confirmed and good to go ahead, unless stated otherwise. We also go through a rundown of the upcoming events at the monthly meeting (first Wednesday of the month).
All in all, there is a lot more coming up than what is on the calendar. Keep an eye out and you will be impressed. ;)
Cheers,
Tony
Just had a look at all star tuning and performance, just from looking at his web page it's very impressive. Has anyone ever taken there car to mercury Motorsport or heard anything about them?
  • Like 1
There's a few bad reports about MM including mine in the R35 section, I would strongly advise you go see Gavin Woods at Labrador, a lot of guys use him including myself and he is well experienced with skylines, even GTR35's.
you can also use a Power FC and run E-flex, my car for example does and I havnt had any problems with it,
Tohmez run with what angry said about MM and I have asked the same question about tuners in brisy north side in particular and I am guna go see all star as isn't to far from me and highly recommended by many!
Tony thanks for the info on additional events got me more psyched again to enjoy the common interest with everyone on here that others without skylines don't get !!! Look forward to see everyone's machines and gain valuable advice !
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
