Where are the pics people! Damn it's been quiet in here. Although, so have I. Been busy.
Anyway, here's one you might of seen. Shot on the side of the road in the hunter whilst sipping on some wine. If you haven't been, highly recommend it!
EDIT: Posted this off my phone and clearly it's compressed pretty bad :( Damn. Oh well. You get the picture. CWUTIDIDTHAR?!
Edited by FST513
https://www.sau.com.au/forums/topic/428333-july-photo-thread/
Its the HDR. Too much HDR and too much photochop has killed photography for anyone not wanting to spend endless hours fking about with multiple exposures of the same scene. It is just out of control.
Great pic. What a view! Nice car as well :P
Car we picked up last night for my mate :D
First time using PS. Open to criticism what i did right/wrong.
It's a good shot for a documentary shot. Doesn't look like you were trying anything here so can't really criticise or anything unless i know what you were trying.
Nice car though! Hope the apex seals last :D
mind explaining what's good/bad about the HDR phase?
Done well on landscape shots etc it allow the photo to be more like what you see with your eye as the final image has the high dynamic range that the name suggests. So the dark bits arent so dark and the light bits arent overexposed.
But you can select too much range and this ends up giving the photo a sort of artificial/chrome look to them. And you see that everywhere - in car mags, on websites. It is just overdone and everywhere and to be honest I am over it.
Eg
http://www.smashingmagazine.com/2008/03/10/35-fantastic-hdr-pictures/
Not fantastic IMHO. I just wish the grown up photographers would use it less.
I've got a couple more shots from holiday. But I do have to admit to being a bit lazy. Even though I brought three cameras (FZ200, GH2 and Sony Action Cam) I pretty much did all my shooting with the point and shoot FZ200.
It has nearly fit my needs for a Full HD Video, extra long and decent wide zoom, and hi-frame rate slow mo video. Just the sensor is small and gets noisy as light drops.
That old pac shot is pretty rad.
HDR 99.% kills shots. Well, if you can tell it's HDR anyway. Best HDR are ones where you can't tell I reckon. There are exceptions to the rule though, like everything. Look up Trey Ratcliff. http://www.stuckincustoms.com/ He's hardcore HDR but he does it really well and tastefully!
nice work Dan!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
