Hamstring issue really plays up on leg press, didn't hurt during squats but couldn't do my usual weights. I think it may be due to my right knee bending in when squatting and I'm causing injury. A guy said I should look at knee wraps or bands when squatting, what do you think?
great efforts Leesh. You should be able to focus on the squat technique without those things, at the rep range you are doing.
You still have a shoulder issue? Are you still doing behind the head standing press?
Okay I'll focus on keeping knees out without those. Hamstring hurt walking to work.
Yeah its getting better but not 100% Started shoulder press last night for first time in 8 weeks; changed technique though
Shoulder wise, if you have inpingement , then it's not going to be better doing bench or shoulder press. If you don't then all good but, be aware that rehab work is important. I don't see the rehab in your workout? Perhaps you are doing it but, not writing it down.
Good to hear about technique. I assume you are now doing seated press in font as opposed to standing behind the neck?
no rehab, I'm doing the program Birds just made up for me.. he didn't give me any rehab to do
No I'm not doing it infront, just not going down past the ear
Do you want some rehab movements? Can help there if you like.
Ask Birds to give you an alternative shoulder movement, seated. At least that way you can train full ROM.
yes please, that would be great thanks
Hmm, can't I just do shoulder press seated?
Sure . I will ping some info up later for you.
You can do the press seated , great idea. In front of the head is good for the pressing movement . Find a seat with a slight recline on the back support to make it straight forward.
Here are some that won't mess up your normal routines and will do wonders, injury or not. This is rehab stuff assuming we take it easy. Once there is improvement you can add something resistance wise , like cuban press.
You can youtube search these ones, to make it easy.
Total shoulder girdle health . Do these 3 times a week. Can do them at home in some cases.
1) Serratus Anterior (Activation movements) are in here for you which should help. This sucker stabilses the scapular movement,
a) Scapular pushups. Just a pushup with you extending and retracting the shoulder blades. The movement is shallow( no where near the ground , motion is small) .The arms straight. Do 3 sets of 20-25
b) Single dumbel scapular protraction. Lay on a bench. Fairly light weight dumbell in one hand straight up. Straight arm. As above move the dumbel up and down with the scapular motion. 20-25 reps as above.
c) Scapular wall slides.
d) Prone Cobras held for time.
e) External rotator bands
f) Shoulder dislocates with band or a stick ( can use a barbell if you are strong).
Try these ones for a month.
26/09/13
Squats
35kg x 10
40kg x 10
45kg x 10
50kg x 8
55kg x 3
60kg x 0
Bench Press
25kg x 10
30kg x 10
35kg x 10
40kg x 4
45kg x 0
45 Leg Press
80kg x 10
90kg x 10
100kg x 10
110kg x 10
120kg x 10
130kg x 10
140kg x 10
150kg x 6
Chin-ups
8
7
6
6
5
5
Shoulder Press
10kg x 10
10kg x 10
15kg x 10
15kg x 10
20kg x 5
20kg x 6
Seated Row
20kg x 10
30kg x 10
35kg x 10
40kg x 10
45kg x 10
50kg x 5
55kg x 1
Hamstring Curl
20kg x 10
20kg x 10
27.5kg x 10
27.5kg x 10
30kg x 6
30kg x 6
35kg x 2
40kg x 1
Bicep Curl
15kg x 10
15kg x 10
15kg x 10
20kg x 6
20kg x 5
20kg x 3
Captains Chair Leg Raises
20
20
20
20
20
Knee Raises
20
Ab Crunches
60
Just saw this.
Either:
a) tie a theraband around your knees and force them out while squatting
OR
b) get someone to wrap a band around your leg (just above the knee) and pull it towards them, while you lunge (they should be pulling the band from the inside edge of your knee). Force your knee outwards (track knee in line with foot) so that it doesn't fall inwards.
I would recommend the latter
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
