On my evo the oem side mount oil cooler (even though it gets air from the front of the car) doesn't evacuate into the wheel well efficiently and temps skyrocket after a few laps on a hot day.
I've rigged up a water spray which I need to better test, but should help.
Just thinking you might need something similar or use a 12v fan if airflow isn't available.
Ps. my r34 loves the oil cooler in front of the radiator.
  • Like 1
Really, I found the oil temps lower with it in that location.
  • Like 1
Problem with it in front of your radiator is it can cause coolant temp problems on the track. To solve air flow issues with it side mounted you can Swiss cheese the inner guard if your still running it
Not sure if you saw, there is a major air flow issue. No air getting to it.
I'm not running guide liners at the moment, but will be when I've got time to make some.
I did think about re-locating in-between the intercooler and the radiator. But I want to keep water temps as low as possible. I've run it there previously and both water and oil temps were higher under sustained load.
Work on the car last night.
As is always the case, things take a while. It was 7PM before we left finally.
Then to wake up the next morning to a missing left wing end plate (fasteners came loose, lost it on the hwy somewhere) and ice.
1.35 on a drying track pedaling around at 80% bedding things in. I thought for sure I was on A050's, the AD08R straight off the bat surprised me. Seems like they are going to live up to their hype.
You can see the NACA duct here, doh!
  • Like 1
With the splitter on now, 1.34 again on a drying track (the damn rain kept coming through).
Not sure what the temp was, cold! mother F$%ing cold.
Dropped the pressures back to 30-31 hot
1.33.38 on AD08R's, street tyres. Love em, such a progressive and predictable tyre. Did a lot of laps in both wet and dry during the day, 40'ish. Tyres still look very new.
After working on the car all week after work and 16 hours on Friday, I was pretty tired and my brain started going off in the last session I did. 1.32.8 was the optimal time on the lap timer for the day and that was easily achievable. I made mistakes on all my hot laps in the last session. With more practice without ABS (this is only my 3rd time) and a more speed conducive day 1.31's are a go'er.
  • Like 1
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
