Winton Weekend - July 9 - 11.
Snowman
 Share
  • Replies 149
Had a great weekend guys. thanks to all..
After the track fully dried they put me at the back of the pack so my third session was a waste. I then asked if I could be put out in front since my times were at least a second in front of the others in group G. So fourth session I did a 1:41.55
Brakes. Oil temp and crappy shocks are still issues to be addressed.
1:41.55 is very impressive mate.
But before you get over confident I just looked up the Maserati Day that was held there at the end of June. None of the big guns went (Ben, JFK, Crazy Tony or Tim - top 4 from Sandown last time out) but there were still 3 cars UNDER 1:30 (best was a 1:27) and a 1:41.55 I think would have got you 11th!
We've all still got a lot of work to do! LOL
Thats amazing...  I felt like I was going almost as fast as I could.
Using the other MSCA entrants as a gauge I was surprised you were getting the lap times you were out of your car.
You were driving well, and suspect that you were straight to within about 90% of what your car, as it stood on the day, has to offer. Going around and around and around another 50 times you may be able to get your times down to about 1:39, but you are still driving a relatively std GTR with cheater tyres... :D
A good comparison will be Snowie when het gets back on the track, id think he would give the WRX club record a fright, considering the times he was knocking out in the Scubie.
Still a best of 1:41 :usuck: , should have kept you running around with 50psi in the tyres :P
Guest
 Share
    • I would avoid the AWD motor in a RWD using a modified RWD sump and pickup. The way the pick up is positioned, you'll have oil pick up issues on hard acceleration on a track around bends. Even with a baffled, gated sump. I suppose if you don't race on a track and it's used for straight line activities or street use you might be ok.
    • They absolutely are, but the thing is, if you're only exposed to these circuits for a while, what I normally think is good driving suddenly isn't so much. I was a pussy at the Nurburgring (GP) entering corners at 180kph - the difference in the balance of the car suddenly becomes so much more pronounced and I'm still a bit regarded at left-foot braking - something I now practice on my commute. So the (dream) plan with the E90 is to make it a 325i Cup car. Whether I get there or not is another matter. In my mind the simplicity of having the NA variant and cost made it a bit more appealing. Plus, like mentioned above, I'm actually too much of a pussy for big power. Of course I f**ked up by not researching enough on the N53 vs N52, the latter being more robust without the DI system.  Suspension-wise on the BMW, and I've been reading the technical requirements for the 325i cup, basically everything except struts has to be standard - bushes are free. I figure you get about 5-10mm adjustment with the rear camber bolts which should translate to 0.5- 1.5 degrees of adjustment. So with coilovers, lowered at 30/40mm I expect I can dial out some of the camber from a drop and attain -1.5 to -2. If necessary, I could get the same effect as the M3 arms with some offset bushes. There is a limitation on ARB width to qualify, although I absolutely want to get either M3 ARBs (can't say sway incase I upset GTSBoy) or the H&R ones - both of these are the cheapest options. Like mentioned, M3 arms are on the way and I should have them fitted within the next week. How are the BC Racing coilovers btw? Reviews are mixed but I think for me they would be fine; a friend of mine uses them on his R34 for track driving and has nothing bad to say. I'm looking at these or the ST coilovers (German brand, new to me) as prescriped the in Cup spec sheet. They're both similarly priced and offer camber adjustment. It's fine but it really upsets my OCD. I've got a couple of options for dialing out the rear camber and keeping my ill-fitting wheels: raise the rear a little bit, say 5mm, that should permit -2.5 camber or drop the front to restore that slight bias of more negative camber up front (not optimal with the roads here). The next alignment won't be until at least next year and I really need to rebuild the rear subframe. For now, I'm not using it at all on the streets except occasional blasts through the German countryside. I was covering about 10k kms p/year in Japan, I expect this to now be about 3-4k. You could say buy better sized wheels, and yes, I should have. But the wheels came from the Z and price of good wheels is just insane now. Again, a couple of options: get a new set (I want 17" RPF1s) or buy two used 9.5J TEs, both are about the same price excluding shipping.
    • by rotating the motor i mean to dismount the plate on the motor and mount it different
    • Sorry I meant to say, Is that $3,500 landed or is that just the sticker price in Japan?
    • Same (except for the R32 bit), my son is saving for his first car which he hopes will be a Kouki V37 GT with the twin turbo 3.0L V6.... kids these days! My first car was a Renault 16 haha 😄 Sorry for the thread hijack
