Just curious as to any experiences with a Nismo 2 way diff in an R33 or anything similar.
I am running a shimmed stock diff now which is pretty nice, although sometime shits me with the whole driveline bouncing thing.
Don't mind the chirping of tyres but don't like the chatter through the tail shaft etc. not sure if the Nismo one would still do this?
Basically have a Nismo 2 way sitting there which I am either going to throw into the car or just sell but I know these keen be hard to come by, although it is in and S13/R32 housing so its a bit of mucking around to do the swap and simply test it in my 33 - otherwise i'd just throw it in and see how it goes.
I have been in a car with a Kaaz centre which felt ok, although I prefer the shimmed over a Kaaz, but apparently the Nismo's are a class of their own..?
Has anyone got a Nismo 2 way that can comment? Do they make the car hop up and down or is it just a 'neat chirp' of the tyres?
Any help appreciated.
I got mine pretty cheap of eBay and got it rebuilt... Changed it from 2 way back to 1.5 way and I have to say its a pretty impressive diff!
What oil are you running in it?
I just put a Nismo GT PRO 1.5 way and the oil that came with the centre made the diff sound like it was going to fall out of the car. After the first 1000 kms I put the OS GIKEN 80 W - 250 in it and its quiet as. I might get the rare *clunk* but you hardly notice.
Might be worth a try if you like how the rear feels ATM?
  • Like 1
I test drove a R33 with a Nismo GT Pro diff moons ago before purchasing my previous R33.
Around round abouts and u turns etc.. it would barely lock, but when you gave it some noise the car would be controllable
An added benefit is that the lock up is adjustable, you can pop off the driver side half shaft and adjust how agressive you want the diff to lock up (great for street & track IHMO).
Exactly Paul - didn't see oil mentioned anywhere... Oil plays a massive factor.
I used the Castrol and my GT Pro (1.5) from the start, would still lock in a carpark @ low speed on the lowest setting with some accelerator, but I didn't mind it at all.
Could simply add some Penrite Friction Modifier if I wanted it to be more forgiving. Very much a personal preference type of thing the ole rear diff lock-up.
That said I've had shimmed R200 and a Nismo in a R200 - Nismo is certainly awesome, but take nothing away from a properly shimmed mechanical R200, they do very well for the amount of outlay.
  • Like 1
I had a shimmed diff and the driveshaft came out and spat oil everywhere as my mate is a numpty :P
Having the Nismo 1.5 is one of the best upgrades to the car, it is so predictable so far.... I havent pushed the car hard yet as i am a skirt but when i get the chance i reckon the diff will hold up great! It can be a bit clunky at low speeds but with solid arms and subframe collars etc that is to be expected...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
