Hey guys
A bloke came over the other day to buy my car. While he was pressure testing it he mentioned something that people do to stock intake plenums called "cut and shut". He briefly explained why people do it but also informed me to avoid a car that has had this done to it.
Can someone explain to me what cutting and shutting the intake plenum is and what it does etc?
Cheers
https://www.sau.com.au/forums/topic/430257-cut-and-shut-plenum/
Its moving the throttle body to front of plenum to shorten intercooler piping. pointless as it affects air distribution in the plenum. Nissan spent a while designing it so seems wrong to hack it up
i like this....it "Seems wrong"
is there any anecdotal evidence that it is wrong?
I've seen a number of cars run the chop job, didn't seem to cause any noticeable detriment but they were usually pretty low end setups, 200 ish rwkw or less
the greddy etc were designed as ffp so not really comparable, the people I knew that used to do the chop for people said it still needed the throttle body on an angle towards #1
i'm sure if we had a fluid dynamics tunnel we'd see that the flow is far from ideal, i'd never put one on my car, same as I wouldn't chop the throttle body off the front of the greddy and put it on the side
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
