Well when I first got the AEM, BEFORE I had any suspicions about it's accuracy, my tuner actually commented about how accurate it was. Said it read dead on exactly the same as his. I'm only suspicious now because of how rich it reads, but that could well be my tune.
i'm sold, techedge it is
http://wbo2.com/2j/2j9.htm
So all i need is 2J9 + cables + sensor? (17123)
Yup.
it is a good idea to grab a LX1 display to go with it if you can afford it. that way you can be sure the input settings are correct in the software on your ecu because you can compare it with the external display, also if the car leans out when your into it you can see it on the fly.
I got this depo gauge...seems all right has Bosch sensor..
Started reading lean, turns out my fuel filter needed replacing...replaced fuel filter now wideband reads error...tried to calibrate it but no response.. :unsure:
Pretty sure sensor is still fine , if unit is dead can I just get the techedge so I can link it to my adaptronic?
start again and get a new sensor with the TE. peace of mind is a good thing and they are not very expensive anyway.
I am pretty sure depo is a china brand.
Not sure, Says Japan on their site, was about the same price as AEM so figured it was an entry level unit...hopefully I can get it up and running again..its a cool little gauge but can't find the instruction booklet to figure out why the error code...
Good timing for this thread to pop up... I'd just decided to drop some coin on a wide band unit that I'll have wired in permanently, when I noticed this thread.
I had my eye on a Koso unit from the states, but after reading Guilt-Toy's advice I think I'll go for an 2J9 Tech Edge unit with LX1 display.
Edited by Ryno
Crunch the numbers and find the price difference between the 2J and the 3A models, remember the techedge site doesn't quote gst, the initial pain to your wallet will soon pass and it's much cheaper to buy right the first time.
just curious on why people prefer the tech edge over all in one units such as AEM UEGO, Innovate MTX-L, LC-1, PLX?
Is it because it uses the BOSCH LSU 4.9 sensor instead of the LSU 4.2 sensor?
I bought mine mainly on reputation, a few of the tuners I've spoken to use them, and have told me the people who design and build them know their shit and they are built to a standard not a price. As for the all-in-one gauge and driver, I would have liked a gauge but this was only a secondary consideration, accuracy and quality took priority, after all this is a tuning tool not another dial to rice up my dash. Also the driver will accept uego and multiple bosch sensors.
Mike.
Edited by Missileman
^ fair enough, I don't use widebands to rice up my dash either. I've always used all in one units to street tune my car and my friend's cars, one thing I've notice is that there's always a little lag time between the pedal being depressed vs. the readout from the widebands I've used.
I posted the nistune graph in your other thread and you saw how little lag there was when I jumped off the throttle at 60, about 1/3 of second lag, and that was at minimal gas flow. I believe the techedge gauges would read at the same speed/lag as nistune.
bosch 4.9 mounted before the cat
See how we go :)
I've recently just installed a AEM UEGO gauge on my mate's S15 just right before the cat (japanese downpipe already had a pre welded bung). I'm plugging up his Nistune either this weekend, just waiting to see if his missus will let him out for a day haha
ok....reasons im getting an error or code "03" (as it appears on my unit)...have tried to recalibrate but pushing its button does nothing....
bosch sensor has barely 3000km on it...originally had this problem with not getting enough power, but I fixed this when I rewired it...unit is getting 12v or thereabout and it was working fine until I changed a fuel filter, I also drained the tank a few times...none of which should have any effect on the wideband I thought...i did have it running too rich for a while, have fixed that... pulled sensor out and looks clean...
Anyone got any ideas here, I'm stumped ?
  • 5 weeks later...
Have you check if the O2 sensor is heating up?
this, i have a faulty unit and even though the voltage was being sent to the sensor it would not heat up. you can light a cigarette if it works =p
Take the sensor out of the exhaust and feel it. If it gets hot quickly it is working. Careful you don't burn yourself...
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
