Interesting, I think you are correct, and the first reg could be in the tank, similar to returnless fuel setups. The other rail return reg could be switched in for easy starting, and have no hot fuel returning.
  • 1 year later...
Thread revival!!!!!
I was thinking about how to retain the fpcm and get better current flow to the fuel pump. I'm no electronics guru but don't the solid state relays switch the output voltage in relation to the input voltage? So if there is a 12v input voltage the output will be 12v and if input rises to 13v then output will then allow 13v etc?
If that's the case could the solid state relay input just be the original fuel pump wiring from the fpcm and the output could use direct battery feed for the pump?
It is a loose understand of the relay's operation but i'm happy to be schooled if i'm wrong.
Thread revival!!!!!
All relays do that.
But I was under the impression the solid state relays varied the output voltage to match the input where as an electromagnetic relay input doesn't influence the output it just switches on and off. The input being the switching circuit and the output being the switched. Is that any clearer?
Solid state relays would have a very low saturation voltage. I have one which is supposed to be "fully on" at about 3v, but will still pass through 96% of the source voltage at 1.6v.
Its like an extremely high gain amplifier. You would be best using some other amplifier more suited if you were intending to vary the voltage.
An SS relay works very effectively with PWM however. If you have a PWM controller that cannot supply enough current for a particular fuel pump, it can be used as a gate for a SS relay, but be sure to have a good heat sink for the relays to go on. They get quite hot once you start putting 10+ amps through them.
  • Like 1
Solid state relay I think just means it has no moving parts. It still works the same as a normal relay (in that it uses a smaller circuit to switch on a larger circuit) so it will work the same as a standard relay
You need some sort of voltage amplifier, but I feel like it would be more effort than its worth. If you are worried about the fuel getting too hot by pumping it constantly, then just install a fuel cooler
Yuh, SSRs are not transistors, even though they are effectively the same thing when seen from a long way away. The devil is in the details. That's why they're called SSRs and not "mahoosive transistors ".
If you want to switch a lot of current in the way you describe (ie with gain according to input voltage level) then you're wanting to build something with a number of big high current MOSFETs or similar. Which is what zoomzoom just said, by the way.
  • 3 years later...
Massive thread necro here but has anyone considered doing a complete revamp of the FPCM to use a buck converter instead of just increasing the ground resistance? I figure reducing load on the alternator for other items + no resistor heat dissipation to worry about would be a decent benefit for the 6V/10V modes.
Would this not describe just about all the aftermarket variable speed fuel pump controllers out there?
Pretty sure, yes. PWMing a brushed motor is effectively equivalent to a buck converter.
I think the goal would be to fit the controller into the stock housing + stock harness though. And uprate the power transistors to handle 70-80A.
I'm not sure there's an advantage to retaining 20-30 yo wiring and plugs and trying to desolder them from the old module and build them onto your new board and be constrained by them needing to be in the same place to poke out through the same holes in the casing.....when some new decent connectors and a proper extruded alloy housing to screw the MOSFETs onto and freedom to lay the board out the way it needs to sound like things worth having.
Just PWM it using 100amp SSRs, because they're high current ones you won't need a heatsink, unless you're running multiple pumps off each SSR.
(Assuming you have a capable ECU). The FPCM is garbage, as it's just a BS drop resistor, which is located next to the aerial on R33.
I'm a little bothered by the suggestion of PWM through SSRs.
Conventionally when doing PWM you use a fixed frequency, something in the order of 500Hz would be common** for simple DC power control. You then vary the width of the pulses to control the delivered "power". But that means that the SSR is literally switching on and off at 500Hz (unless you get it to either 0% or 100% ends of the PWM). And AFAIK, SSRs are not meant to be switched that fast.
Anything high power PWM just sounds to me like the output side should be actual MOSFETs (or other transistory devices that like being switched fast) not SSRs that, whilst they may have MOSFETs inside, don't necessarily like being driven that fast.
You look at any circuit designs for high power DC PWM and you don't see any SSRs. You see FETs. Lots of FETs.
**but obviously other PWM applications might like to run at many kHz, and AC PWM control should either be implemented at the same frequency as the supply, or some lower frequency with careful controls in place to prevent DC draw on the mains supply from halfwave switching etc.
I've got it set at 100hz though, seems to work well :)
Had it set at 200hz and everything made an odd hum. The Jaycar SSRs are rated at 0.5ms switch time, so apply some maths and that's smack bang at the 500hz you've mentioned.
Honestly never looked further than the SSRs, because if modern cars use them to control massive fans and electronic water pumps, then controlling a fuel pump surely should work?
*disclaimer, I am no means an engineer, just have an interest about science and excelled at it in high school. I actually work in IT lol.
Yeah, but I think there's a difference between using them as relays and just simply switching the big loads on and off at normal rates, vs. banging them on and off hundreds of times per second.
I think the Jaycar SSR switching rate that you mention is not "you can drive it this fast". I think it is "It will change output state this fast after you change the input state".
Are you insinuating they might arc to death? I did have that suspicion too hence I'm running 2x SSRs, one for each 460L Wallahbro pump. Each of the SSRs are rated at 100amp (max load that is) however I'm assuming each pump would only drain a theoretic max of approx. 20amp at the fuel pressure I intent to run them at.
A SSR cannot "arc" as part of normal operation.
Without an oscilloscope, you can't characterise any particular SSR, except trusting the datasheet. Or trust the ebay listing details - lol.
From memory, I was able to use those cheap fotek ones up to switching a 1kHz square wave. But I've never used them in anything critical like a fuel pump.
The problem with switching frequency is that you increase the time spent in a transition region between on and off states, where the power dissipated in the switching element is the product of the current and voltage across the device. Eventually it reaches a frequency where the device is floating in a partially on state - which is bad news.
I doubt any ECUs take the PWM frequency that high though, they only seem to go to a few hundred Hz tops, and it should be adjustable.
Also be sure that you SSR is legit. From memory a youtube creator called Big Clive did a tear down of one, only to find a measly 10-15amp rated  TRIAC as the switching element.
Anyway, an oscilloscope is the tool to measure this stuff.
  • Like 1
Yeah, I was gunna say this. I'm not sure what the path to failure would look like for a mistreated SSR. As zoomzoom says above, when they float between on and off they consume a lot of power themselves and will get hot, which could fail gracefully..... or in a fire. I also don't know how much abuse (intensity &/or duration) they can cop. Arguably, switching them at hundreds of Hz for many hours is an enormous number of state changes. 2000 hours at 100Hz is 720 million state changes. It's probably OK.....but it sounds like it adds up quick. It would take a few years of commuting to get 2000 hours. 2000 hours of track use would either come much sooner or never, depending on the type of track usage. A truck would do 2000 hours in ~6 months.
I'm not shitcanning the idea, just mentioning that I think it is not the way that they are intended to be used.
  • Like 1
Might have to go back to the drawing board now with what you guys have mentioned :(
Thought I was being smart by not staging pumps (Not my cup of tea because you get pressure spikes as pumps come online). Not visible on a gauge but definitely visible when you run fuel pressure sensors.
From what I gather I should just bin the whole fuel pumps running on PWM and just have them full noise with a massive fuel cooler to manage heat.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
