bit of an usual one guys but here goes....
So I have a R34 Rb25DET Neo with Tomei spec 2 cams, cometic triple layer head gasket, ARP head studs, high, mount, greddy plenum, pfc usual kind of stuff everyone has now days...
I was driving it yesterday down the fwy, when I pulled off the fwy I noticed my temp was at 106, I wasn't far from my mates house so I kept driving to his house, keeping an eye on the temp and it wasn't increasing as I was moving, I know this is still bad.... Anyway as im just about to pull into his street I notice my oil temp is almost maxed out on my temp gauge. So I shut the motor down and let it cool.
We found the cause of why the car got hot, simple coolant leak under plenum, repaired leaked, refilled with water, rebleed system and all seems fine now. The problem I am concerned about is now when it idles it seems to be a lot lumpier then it ever was before with the cams. I drove the car about 40km home, cracked gate a few times and all seems to be as normal.
I am wondering now if maybe serious damage has been done inside the motor after heating it so much? I am doing to dump all oil and water this week and change out the plugs, prob do a compression test also just to make sure all is OK.
Any ideas? anyone heard of this before? Should I check anything else?
  • Like 1
https://www.sau.com.au/forums/topic/430498-very-hot-neo/
If you had local boiling in the head, or even if it was just dry in the head because you lost some coolant, then the head could have been hot enough to warp. I'd consider taking it to someone you trust to have a once over and perhaps look for any tell tales they might notice that you don't that there is a bigger problem than you'd hope for.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6976340
It may have been alot hotter than the gauge says too, if it's lost enough water to overheat there may not have been enough water left in the system to give the sender a decent reading, probably why it didn't go up more as you drove further, doesn't sound good at all
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6976775
Doesn't sound good man. A note whenever the engine is running hotter than usual is to switch on your heater to max heat max speed. Ill keep an eye on this thread. I suspect the head may have been exposed to too much heat for too long and potentially warped which is a common effect of overheating. I just dont know how you diagnose this.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6976809
Just an update for those that are intrested...
So we did a comp test on the motor last week, found cyl 3-4-5 all down around 115psi! Straite away suspected warped head, so we removed the head and sent it off for X-ray, preasure test and skim. Found head warped hard... Took 3 skims to get flat again but lucky that was the only damage done! No damage to valves and no cracks in the head or damage to the cams so stocked with the results.
Checked the block with a straite edge also just to be double sure and all is fine! Thank f@ck!
I have bought another triple layer Cometic head gasket but after I did I was told u don't need to replace after 1 use specially with the low ks mine had done (approx 3,000)! Does anyone know if this is correct? I'm fitting the new one now anyway but just intrested in finding out of this is correct...
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6997054
As I suggested in another thread, it's not a good idea to skim a warped head. Only the face gets skimmed, leaving the cam towers in a slight arc (might work for a pushrod engine, but not for OHCs). I believe the correct procedure is to shove it in a press and press it flat again - with heat if necessary.
Last head I warped is probably now a boat anchor.
I reckon if you measure the head thickness at both ends and in the middle, you will discover that it is thicker in the middle.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6997466
It depends where the temp was taken from, and if there is no coolant flowing the engine temp could have been much higher...
I have seen 130+ degree water temp at the track without issues, other than a little flash boiling around the bore. I have alloy block and heads though, so the expansion rates are probably closer than cast iron/alloy.
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6999539
I have a greddy plenum so the water temp sensor remains in standard location. The hose on the cold start under the plenum was we're the leak was, the main supply hose let go so it pumped all the coolant out very quik...
I don't think the head was warped too badly as the head guy at first said it doesn't seem too bad with the figures I gave him. I will measure as u guys suggest but I also have arp head studs so maybe I can just tighten it down and pull back down flat?
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-6999861
No idea, didn't measure before sending off!
Can't have been too bad, car was running ok, no water in oil and comp was only down about 15psi...
I'm going to put it back together with stock cams see how it goes, if its no good ill pull it and buy new motor otherwise ill just screw boost and try get some fun out of it before it breaks!
https://www.sau.com.au/forums/topic/430498-very-hot-neo/#findComment-7003927
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
