That it does.
Gearing such as close ratio boxes and holingers n diff ratios make a huge difference in how the car comes onto power. Example CRDs JUN and powertunes r34 gtr. But like you say Ash. Some people don't understand.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981064
Rb30's also love to rev if built right. Ask RIPS. he take a dirty 30 to 9-10k rpm without a fuss. It's just not needed in most cases because of the extra torque they make.
As for the to4z maybe it gets the job done. But today there are better options!
Josh.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981085
That it does.
I love the idea of going through 5 gears getting out my driveway. ..
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981118
inst the crower kit a copy of a spool kit wich was a copy of a nitto?
or am i f**king that up and the spools a copy of the crower?
either way one had shitty rod bolts in it i wich one escapes me at the moment this may be something look into
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981907
I have one of these kits in my R34 (not rb26, it's a gtt)
Note their kit which they market as being 25 or 26 compatible didn't come with pistons that suit the Neo head. I realise this thread is referring to the 26 but worth mentioning for anyone who uses the search feature in the future. I'm sure wherever you get it from can supply pistons to suit but I would definitely ask/confirm/double check/triple confirm before you order to be 700% sure to avoid drama.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981974
Hmm well I'm in the process of deciding to go stroker. I've heard things about mixing up the components from a step 1 and step 2 hks 2.8l kit. Or I will just dump my car at race pace and tell them exactly what is recommended based on my application/intended use. Interesting to see how 2.9 functions from a 2.8.
  • Like 1
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6982061
I'm sure Chris will sort it out one way or another. Last time I spoke to him, he was doing his own 2.8 kit which I believe is in his car right now. As far as the 2.9 goes, these things need all the stroke they can get. Every little bit counts! An extra 1.3 mm is an extra 32.5% more stroke than going from a 2.6 to a "2.8" kit. Bring it on I say :D
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6982383
That it does.
Thanks guys , I think I will be getting this, Speaking of the powertunes R34 gtr , spoke to the guys there who speak highly of BC obviously as they sell it but that GTR is reliable uses B C stroker makes over 1000hp been doing it for 3 yrs been driven heaps even gets street driven and no issues what so ever.
I also spoke to a few other people who have used his stuff with good comments and no issue, read a few posts of ppl who speak highly of them, I will use a new N1 block as a base, strengthen it everyway possible, do lots of headwork, should be good. Will do some more homework offcourse It is not going to be a rushed thing.
Cheers.
Edited by GTRAAH
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6983395
The bc stuff I do hear good things about.
Dont quote me but im sure boost logic are using at least one of their cranks in a 7 sec supra. Will have to find the build again to be 100% sure.
But plenty of guys using them in 2jz's stateside at more than 1000hp with no failures that I have heard of.
  • Like 1
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984180
You either need a shorter driveway or think about parking half way down....
Cheers.
The powertune guys seem to know whats what when it comes to bc and rb's. Best of luck with your engine building mate.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984393
Just thinking about it gets me all excited to do this a lot faster! I guess you've lived and breathed 2.8's far too long ey Piggy? Chris knows his stuff, I'll let him do the hard work lol
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984407
Haha. Well the difference in drive ability and twist between a 2.6 and 2.8 is night and day, lets not even go to a 3.0 or bigger. It baffles me that anyone would consider using a standard stroke length crank when you have it all apart. I realise its more exxy but you get a much better result.
If I didn't have my stroker crank and block, it'll be bigger without hesitation.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984452
Yea I get what you mean, if my engine was apart I would have my engine bored and longer stroke length. The results are just more crisp and can do so much more. Want to chuck some -5's on there with 25-26psi on E85 and aim for high 400's
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984534
I quoted you.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6985389
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
