pt in a high flow cat and a bigger front/dump pipe so now my exhaust is complete..... also put in the new 02 sensor so see if that makes a difference economy wise.... at the moment i get between 250-350 a tank depending how i drive it.... will update if any fuel improvement is made.....
ok results may take longer than expected,,,,, since i changed the 02 and the dump/front pipes at the same time i am driving the car alittle harder due to the fact that the sound of the exhaust is better and i love hearing it and the performance is noticable improved...... it may take a few weeks to settle down and start driving the car as a granny again to compare the fuel consumption issues with the new 02 sensor....... however today i drove from castle hill - manly today via monavale road and back which is a good 80-100km round trip with detour and the petrol droped about 1/8th of a tank, yes this was mainly highway or main road driving but i did gun it a few times so i do belive in the early days that there is some kind of fuel economy improvvement but i will only truely know when i put a whole new tank into it on wednesday and drive it to my usual regime...
to be continued
As there isn't a direct replacement units available for R34 aftermarket, I do suggest going with a genuine Nissan item. These retail for ~$230 however we offer them to SAU members for $194.70 + postage. For the R32/33 there is a direct replacement NTK item available, we offer them for $77 + postage.
Both of these units, and other applications, can be found here.
As there isn't a direct replacement units available for R34 aftermarket, I do suggest going with a genuine Nissan item. These retail for ~$230 however we offer them to SAU members for $176.00 + postage. For the R32/33 there is a direct replacement NTK item available, we offer them for $77 + postage.
PM sent regarding to NTK part number for NTK oxygen sensor to suit an R32 GTS-t
Cheers
well had good results with the el falcon 02 sensor,,,, did 100KM and used 1/8 of the tank guide.... usually i would have already used 1/4 and in reality i have driven the car alittle harder than usual..... after these results i have broken a bolt so the exhaust is leaking pretty bad and i did 25km and am now nearing the 3/4 mark..... so with the early results the el falcon 02 sensor seems to be working..... but i have learnt that a badly leaking exhaust seems to be giving me alittle less power and using more fuel.... atleast the 02 sensor is working lol
After reading through these 16 pages, im still confused. lol
All I've gathered is that changing the o2 sensor has improved the fuel economy of most vehicles.
Could someone be nice and just help me answer 2 questions?
1. Which o2 sensor do i get for the r34GTT? (I dont mind paying a bit more for a 'better' one, i dont want to cut wires or whatever, coz im unco ass)[also like whats the difference between NTK/NISSAN/the faclon ones, generic etc??]
2. and where do i get one in Sydney? (is there a member here who does this kinda stuff in sydney or even the hills area?)
apologies in advanced for my nubness. feel free to PM as to clog up this thread. =)
thanks
Edited by JI34GT
they just measure oxygen in exhaust and either send out a 1 volt electrical inpulse or no impulse (sometimes very low impulse) to the ecu, then the ecu determines if the car can run lean or rich, basically how much petrol and oil to combine at any one time... i used an el falcon 02 sensor, $70.99 from repco in dural just behind bunnings, didnt have to wait around for some idiot to send out a replacement for $77 + postage and handleing..... i got it the day i wanted it.
basically if it screws into your dump pipe and has 3 wires it will work in the r34gtt
to connect the wires is easy, the odd coloured wires from the 02 sensor and the wireing harness connect, then the other 2 wires on the sensor connect to any of the other 2 wires om the loom from the car....
if you want help i can show you, im at castle hill
i installed a new dump/front pipe and high flow cat, since i changed the dump i thought id do the 02 sensor at the same time, didnt wanna spend on a nissan 02 sensor so i went with falcon... so far my tank is showing 1/2 on the dial and ive done 240km (carrying 4 people from city - menai in peak hour traffic.... and wityh the extra power my car has ive been driving it a little harder than usual), before the 02 sensor i would get 300-350 maximum out of a tank (till the dial hits the bottom end of empty), driving like a granny and never carrying more than 1 passenger.... i am expecting to easily get to 400km before i hit the empty line, hopefully more....
i can wire it for you if you bring it to me or if your not too far and if you undo the old 02 sensor first, they are a bastard to unbolt and i dont have the tools, my old 02 sensor is still bolted to my old dump pipe because it was too dificult to undo...
also dont listen to anyone who says the falcon one is not as good as the nissan one, it may not have been made for nissan but it does the exact same job and has been doing the same job for atleast the past few years as proven by the forum entries by other people
Hi guys, does anyone know how to check o2 sensor? the reason is i'm just about to replace my new dump pipe and i wanna see if my o2 sensor still in good working order, otherwise i wanna change it as the same time as dump pipe
thanks for all inputs guys
Cheers
Edited by HCR32R
not really mod, just cut, twist and electrical tape it..... anyway what ever suits you i guess
also first time since owning the car,,,,, went to servo tonight and only paid $51 instad of $75 for a full tank, same driving as usual, still did 300km from last fill but i saved over $20 this week, i want to run it till empty but i also dont wanna have to fill up when petrol price cycle is at its peak,,,,,, petrol price was $1.50 / L
  • 4 weeks later...
Hey guys just changed my O2 man was it a bitch to get off damn those things are on tight, I guess because outside o2 will mess up the readings so it's understandable but just wanted to let everyone know that East Coast Auto spares sells the socket for $27 and they are great ppl to deal with. I just bought it and I doubt I'll really ever be using it again that much so if your in the area your welcome to stop by and use it, if you got a few bucks to spare it will be great to get lower what i paid for it but if your strapped for cash then don't worry about it just PM and I'll let you know when you can come by and use it. Also I made a small video for people that want to see what it's like changing the O2 sensor it needs lots of editing but I'll upload it soon
PS. Initial results are that my engine is running a lot leaner now which I'm glad cause I always thought it was running too rich also white smoke started to come out of the exhaust, if this happens to you don't panic it's fine, only should be worked if there is tons of it or the smoke is black
Genuine just too expensive, grabbed an aftermarket one off ebay for around 90 .. a NTK one :O
Sorry to bust your bubble but if you would have read the thread, you would have seen that Kudosmotorsports is offering brand new NTK ones for $77 + P/H which makes it ~$86 express (Express being I ordered it at 4am on Tuesday, I got it in the moning on Thursday)
Well to be exact it was $88 express posted, so $2 ain't that bad :O
  • 2 months later...
Guys, can anyone advise the output voltage from the R32 GTR Titania O2 sensors???
Mine cycle nice at 2000 rpm, but at idle.....Front one is 0.9 volt constrant, rear one is all over the place between 0V and 1.9~2.0V........I have a harsh idle, no wonder given one sensors not working :D
i thought they had an output of 0-1volt???
  • 1 month later...
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
