Kane's Gr34Tr Build
Simply amazing car. WOW!
Is that the Garage Defend cooling panel?
Also the Nismo Weldina Ne-1, was that too small for 300kw engine?
Are you still running the HKS exhaust?
I can see how addictive building a car like this can become.
Cheers,
GTR hoon: yes it is the garage defend panel, and yeah the Nismo ne1 exhaust flowed my 324kw easy :)
And I do still have the hks exhaust on, with the lumpy can it sounds so tough
Piggaz: why so little boost... Because stock engine..... And stock studs and head gasket :)
The above will be the next step :)
Sir_rb: yes 380kw was my round figure.... I didn't want to push to much boost as I wasn't keen on doing head gasket and studs just now... Hence only pushing 21.5psi
The car was already at jez's for 3 and a bit months, didn't feel like it being there much longer :P
  • 8 months later...
ok so its been a long while since I updated this,
hasn't had any work done to it for a long time but a month ago got a few things done.
I saw that the temperatures in the coolant and oil were getting a bit higher than usual so I decided to bite the bullet and just change all the cooling
so peace of mind that I knew it was all knew and up to date :)
so I ordered:
greddy oil cooler
koyo radiator
nismo therostat
new radiator hoses
while it was at the tuners I decided I might aswell get other things done aswell due to it being there anyway
so got some arp head studs and tomei valve springs put in aswell :)
car now makes 388kw @ 20psi
  • 1 month later...
  • 9 months later...
 Share
