How can I open my boot, on my 1996 GTS skyline.
Should I see a locksmith / panel beater / mechanic or is there a simple way to attend to this?
My son was playing around with the boot mechanism and he pushed something into the down position.
Now I can not open the boot from inside the cabin.
It seems the cable has somehow been disengaged, when I pull on the lever as there is no resistance .
The key hasn't opened the boot for many years so I just open it from inside the cabin. I think the lock was replaced many years back and no key came with it. It has opened flawlessly from inside the cabin.
What are my options for fixing this. All my tools are in the boot. :verymad: :verymad: :verymad: :verymad: . Of course so is my spare Tyre.
thanks in advance
thanks in advance
Just take out your backseat?
There will be a hole you can climb through to gain boot access.......and then you'll be able to sort out the problem.
But the mechanism which was pushed down needs to be moved into the up position. With the boot engaged in the locked position can I actually access that lever. I think the tongue from the boot lid prevents me from accessing it ?
Doesn't work in a 33 unless you can also shrink yourself.
I'd try with the key and see what that does. Or even try the key and the lever at the same time
Back seats taken out (see photo attachment), but its impossible to access due to opening size, rear battery on right and compartment location on left along with significant electrical wiring which would have to be disconnected.
Turns out the barrel did belong to the ignition key and a prolonged deep spray ,with a thin tube inserted ,of wd 40 eventually allowed the key to open the boot, though its not reliable, even after having sprayed. Reversed the boot switch and now will open only from inside the cabin .
Thanks all
Is the key or the key barrel tired? If its the key then Suggest you get the key code and get another key cut or you could be doing this all over again
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
