Is there any specific way of cleaning and detailing an engine/ engine bay? Or is a few cans of HD degreaser and anf well used Gernie and a little towel action the only way to go? This is the reason I ask.
As you can see she's got quite a dirty heart in her.
Any hints and tips reslly appreciated, many thanks in advance.
  • Like 1
https://www.sau.com.au/forums/topic/431532-engine-bay-cleaning/
I watched this the other day, I know a skyline is better then what he's working on but it still helps
Thank you that was exactly the information I was looking for.
(This post can be locked now mods.)
I picked up a free sample bottle of Simple Green from Bursons a couple of weeks ago.
I'dd tried a ton of different solutions and nothing has worked as well as this so far. Mind you i was using it as a 100% concentrate! :woot:
A good tip is to buy a ton of small tooth brushes and melt the handles into suitable angles to get to the harder spots :)
  • Like 1
i have been detailing my car every 3 weeks for 4 years and you just blew my mind. thank you sir!
I find Prepsol for painted surfaces in the engine bay works really well to remove oily, fuel, greasy stains. Just give it a good rub while it's wet.
(Especially good for the fume stains on the underside of the bonnet)
Tin foil (out of the pantry) is flexible to work over/around electrical connections (real easy).
Plastic shopping bag over the airfilter/s.
Degreaser for the engine as per the vid.
Rinse down/dry off.
Depending if your picky you can then use a mild cutting/polish compound on the engine bay painted surfaces like struts etc. Micro fibre off and then wax. Easier to clean next time.
Stiff paintbrush is a good tip from the vid as with old tooth brushes mentioned above^^.
Giving the hoses a quick wipe over with an interior cleaner brings them up shiney.
And of course if you have shiney metal :( then a metal all purpose cleaner after a metal polish makes it look tits :D
Using one of those power cones for polishing makes it a lot easier :)
Edited by Anonymouse
Ha glad i could help.
I'm by nature a tight arse so anything to save $$. Besides owning a gtr isnt cheap.. gotta cut some corners somewhere :)
  • 1 month later...
  • 1 month later...
  • 1 month later...
diluted ct18 does wonders with a little elbow grease.
yep or dishwashing liquid...Prepsol as mentioned ,is great for cleaning those smokey stains of your paint and get heaps of those 5 for 10$ degreaser cans from supercheap...they blow grime off in places you cant reach...or if you have a air compressor buy a degreaser gun...
I always end up with water in down with my coils always have to take the cover off and blow it all out with an air gun, I also blow off excess water on any terminals afterwards as well
yeah,, what I did was take the cover off and get some off that foam sticky tape...put a piece down either side of the cover and replace...works well...
alternatively, remove cover and put a towel over your coilpacks...
but really you shouldnt need to spray the top of the engine that much as most of the grim is down the sides where oils leak...just spray around it mostly
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
