I got a call from Lester saying I need a high end apartment for better jobs (heists maybe?), as mine was a $135,000 apartment. So I guess I need $300,000+ now :(
does it need to be a 300k one? or one of the 10 car garage ones? the cheaper 10 car garage ones are around 200k, that's what i was saving up for. Do they also have the heist planning rooms?
The missions get better as you go.
I just done a mission for Trevor Phillips Industries where you steal a Leerjet off a beach and deliver it to his runway. And another one where you get in a chopper with a crew member, who is on the surveillence camera, identify a target, parachute in, kill him, take a photo of his killed body, and deliver the picture to Madrazo.
Level 20 for reference sake.
Edited by Shazbanger
Another update this morning.
Did the first job for Simieon. Shot the guy but then missed him and he took off. Ended up chasing him halfway around the map and delivered the car with nothing in-tact. Still a great job according to old mate :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
