after 8pm and if im online, im going to be grinding away at "down the drain" race, 1 lap races and ill most probably invite crew members most times, jump on board for easy cash.
mix it up with different car classes but its a bit tediouse. good cash and good experiance though, best i have found so far.
can be fun too.
The Stimulus Package only applies to players who joined Online in October, only.
need to get as many SAU people playing "down the drain"
make it a one lap race, over and over as you get about 3-15K every race, which is like 3 mins long. great to level up and get cash!!!
You all on XBOX or PS3?
I am on PS3
Rank 23 atm.
ps3
ps3 and yes i joined in octoBER!!
WINNINGIN I SHOULD HAVE IT
Cool!
I might have to join the SAU Crew or just Invite you both if I wanna do a Mission.
What's your Gamer Tags on PSN?
PM if you want.
I mainly do Solo / Invite Session as I am wanting to level up.
I do them to unlock more car mods. My pink scooter and Sandking XL need some more loving.
Super pissed off at some of the % spawn rates for average cars. Blista's are next to impossible to find if not low level, even in single player. The commercial vans are cool too, slammed on tuner wheels with rollbar and white wall tyres. bawlla
Cool!
PM if you want.
psn nick is: emmadamo
yes mine and my partners name! add me up guys and gals
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
