had some fun races with ghost last night, freaking hate the cardboard on 'down the drain', coming first by a mile and then car just flips/does a 360 into a wall......FML
will be on again tonight!
haha yeah they mix it up abit, try it on bikes :P
leaning forward hard for speed then wwooOOOooop 10m in the air on ya head.
gh05t again i think
psn nick is: emmadamo
yes mine and my partners name! add me up guys and gals
Cool!
I will try and find you all and add to the friends list.
Thanks!
Mines: Wrath_Of_Power
yeah i took a jet successfully last night. parachutted in and some how managed to land on the jet, took it got away and went buzzing highways and blowing up everything i could. good fun
also, how shit is TopFun III
get in plane, fly in streight line to hanger, land.
after Topfun I and II which were awesome to play.
when i was playing with you, i accidentally ejected out of the jet (WOW this sentence is really ghey) and had to parachute down and get another jet...halfway across the map, you finished the mission.
whos got private servers?
no one.
you just create a private session and invite the crew.
Whats say a big SKAU meet up this friday night...or even Saturday night. Private severs and the like....
never anyone on a fri or sat.
years of on-line experience says Thursday is the best night for getting gamers together.
but no reason why this cant be done all 3 nights
Thursday at 8 I thought was the plan?
Private SAU session. Winning.
Not sure what to do with those of us who dont have Mic's. Might see If I can get my bluetooth keyboard to work with the PS3 again
just buy one! actually, any old bluetooth mic should be able to pair up with your PS3. the official PS3 ones are only ~35$ now anyways!
Yeah I have an old bluetooth headset from one of my old phones I've been meaning to try. But usually its more fun not to have one because noone can hear you rage lol
Might be good if its just SAU'ers involved
Dunno about the PS3 ones, but Xbox wireless mic is awesome. Has a big mute button on the side that you push and then no one can hear you rage. Will beep every 5 seconds to tell you it's in mute mode. Heaps better than the wired headset.
Yesterday online was full of Dubstas which are worth 7k a pop at LSC, so here's my garage full of Dubstas after I started collecting lol
Everytime you log on, or every 48 minutes, if there are crap cars on the road, you can just take one of these babies down there for a quick 7k.
Oh and for the guy who was swapping in and out of passive mode to kill/troll people...I tried that...as soon as I disabled it I couldn't access weapon wheel for 10 seconds but the guy I was following could shoot me on foot. It must put you out of passive mode for other players straight away, but you have to wait.
Also people with tanks are starting to get really annoying.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
