  • 1 month later...
had some friends over the other day and had 2 playstations on 2 TVs next to each other... and I couldnt believe how f**king difficult it was to get a game going sitting next to each other.
We all got so frustrated at the cops ruining our fun and the massive load times/crashes.
Decided next time we returning to GTA4 on PC for proper shenanigans.
a) its easy to use and setup
b) simple trainer.
c) see b).
Did try out the new race editor on GTAO and it was kind of like a very restricted forge for Halo. Was funny for about 10mins making a golf course deathmatch filled with tonka trucks and massive yachts in the small lakes, and then testing contanstly respawning AI with golf clubs.
But hours of fun was had making a race course starting at the top of mt chilliad and rolling the whole way down without dying, then trying to reach near-impossible checkpoints on pier with large vehicles :P
Yeah I still have alot of fun playing it. Been making a heap of cash the past few times I played
Should have a crew night sometime. More RP and cash plus can get some shit done (getting everyone some race wins for mods etc)
  • 1 month later...
Neat little easter egg I found:
when you go to buy the Elegy RH8 (R35 clone) online, the caption says "you can finally own this legendary supercar slayer without the fear of having your door kicked in by the FIB because they'd rather crush import cars than catch terrorists".
A reference to the Motorex Skyline seizures?
Haha, I'm just imagining some really cynical bitter skyline fan working over there at Rockstar
  • Like 2
  • 2 months later...
  • 1 month later...
  • 3 weeks later...
Yeah can only guess. I havent played in a while.
I just remember there was talk of the August update (I think) including Hesits but it never did
eh, been playing 'The Last of Us' when I finish that I might go back to GTA online
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
