Hi guys, I've been planning on a 30/26. The 26 I have has factory bottom end and worked head making about 500hp with all the bolt on to do so.
I've been out on the track with it a couple of times and had no problems.
Motor and box are out at the moment to put a extended sump and oil head drain.
Bought the car being told the bottom end was fully built. When we took the sump off we discovered it is stock....
So do I just put the 26 back in or do I go a forged rb30/26? The car will be 90% track. Cheers
https://www.sau.com.au/forums/topic/433110-to-3026-or-keep-the-26/
If you're going to do it I wouldn't personally bother with a stock bottom end. Too low in comp. IF you're using it for track you'll want more comp to give you more stick out of the corners. Fine if you're using it for the strip as you can pump in more boostage.
Mate 370kws at the wheels is nothing to laugh at. If it's making good reliable power with good response as it is I'd leave it. One of the reasons I went 30/26 was to make the jump from low 300's to low 400's. For you the jump isn't as big (unless you have a fair crack at it) so that may help in the decision to stay with what you've got.
Put half of the money in to your current setup as a (proper) RB30 build will cost you and you've got a pretty amazing engine.
I'm with Shoota77
Measure your bores and if they are within tolerances put your engine back together with rings and bearings if necessary (or if you're keen a set of forged pistons and a balance) and it will probably go for years. I have an RB30 with a stock bottom end in my Stagea and it is heaps better than the original RB25 and really torquey but its not making 370awkw. You would want a fully forged and balanced RB30 to see a significant improvement on your RB26 and probably end up spending a minimum $10k or easily double that depending on how carried away you get. Your current setup sounds pretty good and you could fairly easily get a few more KW if you really want.
Hmmmm yeh. It is responsive as is. I just wonder how much more it can be with the 30 bottom. Sorry guys, this suggestion of keeping my existing engine has has thrown a spanner in the works and confused me.
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
